ECU question
Old Sep 13, 2004 | 07:31 PM
MooreBoost's Avatar
Default ECU question
I have a DOHC ZC with an 88 Integra ECU, and were going to swap it for a built d15b7. My question is, can I have the Integra ECU chipped with Turboedit to run the d15, or do I need to get a new ECU specifically for the d15?
Old Sep 14, 2004 | 07:13 AM
MooreBoost's Avatar
Default Re: ECU question (tegunderpressure)
Old Sep 14, 2004 | 07:22 AM
4drEF's Avatar
Keyboard Humorist
B7 is OBD-1 so you need to downgrade that motor to preOBD spec and then it will run with TurboEdit.
Old Sep 14, 2004 | 07:57 AM
MooreBoost's Avatar
Default Re: ECU question (4drEF)
So I may as well just get the B7 ECU right? And it will still plug into the engine harness right?
Old Sep 14, 2004 | 08:19 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">So I may as well just get the B7 ECU right? And it will still plug into the engine harness right?</TD></TR></TABLE>
Different OBD ECU's aren't compatible with different underdash harnesses.
You would need an OBD-1 to OBD-0 jumper harness to run the B7 ECU.
Like this one - http://www.boomslang.us/obd0.htm
You could just use the distributor and single wire O2 sensor from your ZC and put them on the B7 motor. Then you can use your TurboEdit ECU.
Old Sep 14, 2004 | 01:12 PM
MooreBoost's Avatar
Would a PM8 ECU from an 89 CRX HF work? With the harness?
Old Sep 14, 2004 | 01:25 PM
bambam's Avatar
A B7 and B2 are internally the same motor just different obd's. Bolt on an A6 dizzy to the B7 head. You will be able to run the B7 with your 88 teg ecu (PG7) just fine. You did say it was built right? The PG7 is setup for a D16, your motor is a D15. Won't be a problem.
Old Sep 14, 2004 | 01:30 PM
Speed PHreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
COrrect me if I'm werong but doesn't the ZC distributor lack the interal 'cam angle' sensor like the other obd-0 mpfi dizzys? I"m pretty sure that big round sensor on the exhaust cam is something important....
I'm just wondering if the ZC dizzy would work right since it's missing a sensor...I guess i'm not a ZC freak.
Would a PM8 ECU from an 89 CRX HF work? With the harness?</TD></TR></TABLE>
No it would run incredibly lean and would thorw a code for the EGR valve the B7 is missing.
Old Sep 14, 2004 | 01:31 PM
MooreBoost's Avatar
Default Re: ECU question (bambam)
So youre saying if I swap the ZC distributor to the B7 I can run the 88 Teg ECU?
Old Sep 14, 2004 | 01:32 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Would a PM8 ECU from an 89 CRX HF work? With the harness?</TD></TR></TABLE>
No harness needed for that. The HF is OBD-0 and will plug into your OBD-0 underdash harness.
The problem is that "HF".
It's not a very demanding motor.
It's going to run a bit leaner than it should.
People have tried to run the D16A6 and D16Z6's with that ECU and it's been problem.
Old Sep 14, 2004 | 01:34 PM
MooreBoost's Avatar
People have tried to run the D16A6 and D16Z6's with that ECU and it's been problem.</TD></TR></TABLE>
But I will have it chipped with Turboedit so A/F's will be adjustable.
Old Sep 14, 2004 | 01:36 PM
Hell I tried to run a MPFI converted d15b2 and it ran like ***.
But I will have it chipped with Turboedit so A/F's will be adjustable.</TD></TR></TABLE>
No PM8 is easily chippable. All of them are romless ECU's that require special modifications to be chipable. It would be easiest just to get a stock PM6(D16A6 ecu) and run on that.
Old Sep 14, 2004 | 03:01 PM
Old Sep 14, 2004 | 03:14 PM
4drEF's Avatar
Keyboard Humorist
Default Re: ECU question (Speed PHreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">
I'm just wondering if the ZC dizzy would work right since it's missing a sensor...I guess i'm not a ZC freak.</TD></TR></TABLE>
I think you are right.
I think the DOHC ZC has it external.
Shucks.
Old Sep 14, 2004 | 07:47 PM
bambam's Avatar
just run it off of your current ecu...no change is necessary.
Old Sep 14, 2004 | 07:54 PM
MooreBoost's Avatar
Default Re: (bambam)
My ZC does have the external sensor, so I cant use that distributor correct?
And I should find a PM6 ECU?
Old Sep 14, 2004 | 07:57 PM
bambam's Avatar
Default Re: (tegunderpressure)
LIKE I SAID TWICE ALREADY....USE YOUR CURRENT ECU.
use an A6 dizzy on ur motor and ur done.
Old Sep 14, 2004 | 08:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">LIKE I SAID TWICE ALREADY....USE YOUR CURRENT ECU.
use an A6 dizzy on ur motor and ur done.</TD></TR></TABLE>
josh_db1
May 11, 2010 08:35 AM
JDmspoon22
18
Sep 4, 2007 09:09 AM
ludekid4323
Aug 25, 2006 07:01 AM
PrestonCRX
Mar 16, 2006 06:09 PM
SadisticRacing
Nov 13, 2003 08:53 PM
