d16z6 into a 90crx hf?
my brother is planning on swapping a d16z6 into a 90 crx hf .my ? is will it bolt up without any modofications? thanks in advance. helpppppppppppppppp!
u should really serach, u can use all the mounts that come with the motor except the driver side mount u use ur old mount off the old motor
u can use everything else, make sure u get a si trans
u have two ways to do it
convert to obd1 useing a jumper harness that will activate the vtec and you'll be running a obd1 ecu
or use all ur obd0 stuff and use a vtec controller/msd activation switch/etc.
i went obd1 jumper harness and im running a p28
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">u should really serach, u can use all the mounts that come with the motor except the driver side mount u use ur old mount off the old motor
i went obd1 jumper harness and im running a p28</TD></TR></TABLE>
Easy swap SOHC run like a champ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker »</TD></TR><TR><TD CLASS="quote">obd0 dizzy wont work on the z6 head without being modded....
cant you use the d16z6 dizzy without having to switch to obd1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 »</TD></TR><TR><TD CLASS="quote">
cant you use the d16z6 dizzy without having to switch to obd1?</TD></TR></TABLE>
simple answer...
nope.
CAN'T BE DONE.
The internals are different specifically the number of teeth on the pickup gears.
You have to run an obd1 ecu with an obd1 dizzy and vice versa.
**an obd2 dizzy and obd1 dizzy use the same internals so you can interchange them. The only problem is that the plugs are different and must be changed.
simple answer...
nope.
CAN'T BE DONE.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam »</TD></TR><TR><TD CLASS="quote">
simple answer...
nope.
CAN'T BE DONE.
**an obd2 dizzy and obd1 dizzy use the same internals so you can interchange them. The only problem is that the plugs are different and must be changed.</TD></TR></TABLE>
haha...this is you right - https://honda-tech.com/zerothread?id=926193
so how did you do it 'without problem...on an obo0 ecu' ??
simple answer...
nope.
CAN'T BE DONE.
dont bother using anything obd0, just convert your harness over to obd1 and use a p28 or p08 ecu and get a jumper harness for you ecu from boomslang fabrication. do a search on obd0 to obd1 swap and print out the instructions to do it. converting to obd1 is better in the long run , rpm activated switches are overrated.
http://hybrid2.honda-perf.org/tech/sohcvtec.html
says here that you can use the obd1 distributor with obd0 ecu...are they lying?
