Smoking dipstick? help...
Old Sep 13, 2004 | 06:11 PM
StolenTeg's Avatar
Default Smoking dipstick? help...
Well, i've noticed that a little amount of gray smoke came out of the dip stick hole when the car is idling. But i ddint worry about that until today, today i was driving and decided to play around a little. Floor 2nd and everything is fine shift to 3rd at almost the end of third, A whole bunch of smoke came out of my engine bay and i thought my motor had gone to ****. I pulled the car over and pop the hood, nothing is wrong or leak or oil or coolant whatever anywhere, but i noticed that the dipstick is not in tightly and smoke is coming out of it. so i guess all that smoke come from the dipstick hole, when i rev it a little more smoke also come out. I dont know if this is normal but i dont think it is. The car drive completely fine, but is there something wrong with the car? I wanted to check the compression but dont have access to a tester right now.
Old Sep 13, 2004 | 06:43 PM
Chris F's Avatar
Default Re: Smoking dipstick? help... (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote"> check the compression </TD></TR></TABLE>
Ha, where do you think the smoke might be coming from?
Old Sep 13, 2004 | 06:46 PM
Drew Peacock's Avatar
Default Re: Smoking dipstick? help... (ccfries)
Rings are gone no doubt
Old Sep 13, 2004 | 06:48 PM
StolenTeg's Avatar
Default Re: Smoking dipstick? help... (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Rings are gone no doubt </TD></TR></TABLE>
Damn is it that bad, I rarely beat on the car and it dyno tuned with hondata. **** it be fucked up if that the problem.
Old Sep 13, 2004 | 06:59 PM
old no.7's Avatar
definately check your compression and perform a leak down test if you can access the tools. also check your pcv valve, I had a the same problem before!
Old Sep 13, 2004 | 07:00 PM
iiilgsrlll's Avatar
Damn is it that bad, I rarely beat on the car and it dyno tuned with hondata. **** it be fucked up if that the problem. </TD></TR></TABLE>
Its not always the rings but a good possibility. I had that problem on the dyno this past weekend with a new block. Spittin' a crapload of oil out the dipstick but no smoke anywhere else. My seal on the dipstick is burnt to crisps. If its the rings you would see oil coming out the tailpipe simultaneously. I know i didn't have any smoke coming out the tailpipe. Just the dipstick hole. Get a metal dipstick and see what happens.
Damn is it that bad, I rarely beat on the car and it dyno tuned with hondata. **** it be fucked up if that the problem. </TD></TR></TABLE>Almost undoubtedly, do compression test, but it is most likely blow by you should have smoke coming out of your rocker cover to.. For it to be pushing out the dip stick its probably quite bad, you not over fill with oil or anything dumb are you?
Old Sep 13, 2004 | 08:29 PM
808b18c1boosted's Avatar
Yup sounds like blow by.
Old Sep 13, 2004 | 10:42 PM
calvinPGMFI's Avatar
Default Re: Smoking dipstick? help... (808b18c1boosted)
I think broken rings/ringlands.
Old Sep 14, 2004 | 05:30 AM
StolenTeg's Avatar
what is a blow by and what causes it???
Old Sep 14, 2004 | 05:52 AM
maxspeedhonda's Avatar
blowby is caused by losing compression due to bad piston rings or ringlands. basically, the oil below your piston is escaping past the ring into the combustion chamber where it is burned and produces that wonderful smoke you are seeing. I small amount of blowby is normal, but anything significant will show up on a compression test.
Old Sep 14, 2004 | 07:21 AM
Chris F's Avatar
Default Re: Smoking dipstick? help... (maxspeedhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxspeedhonda &raquo;</TD></TR><TR><TD CLASS="quote">blowby is caused by losing compression due to bad piston rings or ringlands. basically, the oil below your piston is escaping past the ring into the combustion chamber where it is burned and produces that wonderful smoke you are seeing. I small amount of blowby is normal, but anything significant will show up on a compression test.</TD></TR></TABLE>
Some blowby is definitely normal. Maybe your PCV is clogged/plugged?
Old Sep 14, 2004 | 07:27 AM
blundar's Avatar
I was gonna say.... I'd be looking more towards the PCV system being fucked up / inadaquate than the rings shot. I was blowing oil out of the oilcap (with it screwed shut!) on my PCV-less LS/T...
Old Sep 14, 2004 | 08:14 AM
2muchPSI's Avatar
Default Re: (blundar)
this has happened to my friends with DSM's before, it turned out that the oil dip stick was just coming loose because it was worn out, and oil was coming back out of the hole, spewing around and smoking because of the heat. He replaced the dipstick with a new oem one, and problem solved.
Old Sep 14, 2004 | 11:59 PM
IMO it would be better for honda's to remove the pcv all together and go with a endyn type breather catch can. The pcv valve works only under light throttle or vacuum, so when you are at WOT or under boost the valve is shut thus causing even more crank case pressure.
Old Sep 15, 2004 | 02:36 AM
Default Re: (808b18c1boosted)
I just disconnected mine plugged in a line to my catch tank for any vapor.
Old Sep 15, 2004 | 08:12 AM
SdGSR01's Avatar
Default Re: (turbozxi)
where can i find a metal dipstick? I'm having that problem right now, I know for a fact though its because I fried my dipstick.
Old Sep 15, 2004 | 12:20 PM
iiilgsrlll's Avatar
Default Re: (SdGSR01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SdGSR01 &raquo;</TD></TR><TR><TD CLASS="quote">where can i find a metal dipstick? I'm having that problem right now, I know for a fact though its because I fried my dipstick.</TD></TR></TABLE>
The most popular one for the GSR, the STR, has been discontinued. I see that Venom has one for the GSR and there are a number of sites that still might have the STR for other cars such as Civics. I'm not sure how accurate the reading will be when using a dipstick for a Civic but the main purpose is to seal the dipstick hole. Reading the oil level with the STR stick is impossible anyway so always have a stock one on hand when checking the oil level.
You can try JC Whitney online or Importsports in Denver, Colorado. I know for a fact Importsports has some GSR ones in stock because I should be receiving mine tomorrow from them.
Old Sep 15, 2004 | 12:26 PM
SdGSR01's Avatar
Default Re: (iiilgsrlll)
I was checking out the Venom one, but I can't really see it fitting in there with the manifold. Are you using a metal one?
Old Sep 15, 2004 | 12:33 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SdGSR01 &raquo;</TD></TR><TR><TD CLASS="quote">I was checking out the Venom one, but I can't really see it fitting in there with the manifold. Are you using a metal one?</TD></TR></TABLE>
I was using the STR metal one but that got "thrown away" during my motor rebuild so I had to get another one.
There are two different Venom ones. One has no metal rod and the GSR one has a long metal rod so it extends it out over the header.You should double check though.
Old Sep 15, 2004 | 12:58 PM
turbosi03's Avatar
that would be awesome if it was just the dipstick... would be FAR off from my luck, if it was my problem I would have blown ringlands, scared cylinder walls, and a warped head... at least.
good luck!
Old Sep 15, 2004 | 06:12 PM
SdGSR01's Avatar
Default Re: (turbosi03)
Cool I'll definitely be looking into that
Old Sep 15, 2004 | 06:26 PM
Code Blue's Avatar
anyone giggle like a 12 year old when they read the title???
Old Sep 18, 2004 | 12:28 PM
StolenTeg's Avatar
Default Re: (Code Blue)
The smoke is not because of pvc or anything, My cylinder #4 ring is probably gone. compression come out 195 195 195 115. It broke my heart when it stop at 115.
Old Sep 18, 2004 | 01:37 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">anyone giggle like a 12 year old when they read the title???</TD></TR></TABLE>
No, but after I read your post I did. Sick mind lol
