mini-me question
Old Sep 13, 2004 | 05:55 PM
mellon's Avatar
Default mini-me question
I'm wondering if I am required to install a new ecu when doing the mini me swap. I'm going to be putting on a y8 head, will I need the corresponding ecu or will the stock ecu in my '90 CRX Si work until I have enough cash for a p28?
Old Sep 13, 2004 | 06:13 PM
efcivic757's Avatar
a pm6 can work if you run a vtec controller or if you know someone that can modify the pm6. There is a guy near me that can mod it so it will send a vtec signal.
Old Sep 13, 2004 | 06:24 PM
mellon's Avatar
Default Re: (efcivic757)
So as long as I use an rpm switch or something like VAFC to activate vtec it doesn't matter if I change my ecu or not.
Old Sep 13, 2004 | 06:33 PM
sprayedcrx's Avatar
Default Re: mini-me question (mellon)
it can work on your stock ecu if you just run a switch to the vtec or an rpm activated switch
Old Sep 13, 2004 | 06:36 PM
mellon's Avatar
Default Re: mini-me question (sprayedcrx)
Thanks guys, I was worried the y8 head might not like the fuel maps my ecu was giving it, or something like that.
wolf95
Oct 18, 2009 08:50 PM
HatchMo
Jun 24, 2005 08:52 PM
menappi
Mar 14, 2005 05:54 PM
iphatcrxi
Dec 6, 2004 08:30 PM
NYCz DA9
Jan 19, 2003 04:41 PM
