ls rods itr pistons
Old Sep 13, 2004 | 04:44 PM
raifordmotors's Avatar
Default ls rods itr pistons
will i have to do any mods to ls rods when using itr pistons
Old Sep 13, 2004 | 06:02 PM
redlineintegra's Avatar
Default Re: ls rods itr pistons (raifordmotors)
yes, the rod will need to be shaved to fit the piston.
Old Sep 14, 2004 | 10:20 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raifordmotors &raquo;</TD></TR><TR><TD CLASS="quote">will i have to do any mods to ls rods when using itr pistons</TD></TR></TABLE>
Just like putting CTR's on LS Rods! Why are you putting ITR pistons on LS rods anyway! Put P30 pistons on the rods! if these are going into an LS then dont use ITR's, the B16 Pistons will yield the same compression w/o machining the rods to fit!
Old Sep 14, 2004 | 10:59 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: ls rods itr pistons (hybrid_vtec)
yes you will need the rods "pin fit" and i disagree with the last post the itr pistons are better because they are lighter as well as teflon coated
Old Sep 14, 2004 | 02:04 PM
Default Re: ls rods itr pistons (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">yes you will need the rods "pin fit" and i disagree with the last post the itr pistons are better because they are lighter as well as teflon coated </TD></TR></TABLE>
My bad, I forgot about the teflon coating! Not sure on the weight though! USDM ITR Pistons are built have a smaller dome yielding 10.5:1 in an LS while the JDM ITR's and the JDM B16a(P30) Pistons are pretty similiar in dome height(P30 being a lil bit bigger, so it may weigh more but not by much), both yielding in the 11.0:1 to 11.1:1 CR range!
JDM ITR Pistons are not bad Pistons, but I were goin to machine the rods might as well go with the CTR's and get the most you can from OEM Pistons!
Old Sep 14, 2004 | 02:13 PM
ITR Pistons do weigh more than B16 Pistons, however the difference is so minute that it really doesnt matter that much! It's only 11 grams!
Checkout this website:
http://www.theoldone.com/articles/pistons/
Old Sep 14, 2004 | 02:46 PM
DYNO-PRO
GOOD POINT 11 GRAMS DOESNT SEEM MUCH BUT CONSIDER THIS... a 81 mm bseries piston weighs 2 tons at 9k rpms so to me every little bit counts just my 2 cents and yes i was refering to the jdm p73 pistons
Old Sep 15, 2004 | 10:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">GOOD POINT 11 GRAMS DOESNT SEEM MUCH BUT CONSIDER THIS... a 81 mm bseries piston weighs 2 tons at 9k rpms so to me every little bit counts just my 2 cents and yes i was refering to the jdm p73 pistons</TD></TR></TABLE>
Interesting! How did you calculate that! I know that the weight ratio of rod and pistons is 2:1, you want the weight of the pistons to be half the weight of the rods! There is a tolerence of +/- a few grams, but I dont know what that tolerence is!
Old Sep 15, 2004 | 10:22 AM
DYNO-PRO
i just pulled it out of my ***!no really its approx.
Old Sep 15, 2004 | 11:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">i just pulled it out of my ***!no really its approx.</TD></TR></TABLE>
No, I believe you! I just want to know the formula so I know it! Thanx
Old Sep 15, 2004 | 12:43 PM
DYNO-PRO
oh ok my bad i dont have it in my brain give me a little while
Old Sep 15, 2004 | 01:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">oh ok my bad i dont have it in my brain give me a little while</TD></TR></TABLE>
Ok, whenever you get it! Thanx
sik_sol
Sep 24, 2006 05:28 PM
CRX MASE
Mar 31, 2006 09:06 PM
lscoupe
May 18, 2005 02:20 PM
paulzy
Sep 20, 2001 09:12 AM
