I wanna swap my ls intake manifold to a stock gsr manifold
I own a 96 Integra LS. The motor is completely stock and i need more power. My buddy has a 99 gsr intake manifold he wants to sell me. So what i need to know is will the gsr manifold fit my ls without any problems. Also would it be worth the trouble of the swap? Any help is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgbpmp »</TD></TR><TR><TD CLASS="quote">GS-R intake manifolds will not bolt up to an ls head.</TD></TR></TABLE>
that's because the GSR manifold was built for the GSR motor. if it were to be put on an LS, i'm 99% positive that it would cause the LS to lose power
how are you going to activate the secondary butterflies(IAB)? your not running a gsr ecu, and also the bolt pattern won't match up,even if you got it on which i doubt it wll result in a BIG loss of power. answer=SKUNK2 LS manifold
hehe...
This guy is a num-nuts...
GSR manifold never gonna fit on an LS head... and would be a waste of time, no way the secondary butterflies going work.
buy a skunk2 or AEBS....
GSR manifold never gonna fit on an LS head... and would be a waste of time, no way the secondary butterflies going work.buy a skunk2 or AEBS....
i was under the impression that switching out the IM on a stock motor wouldn't do any good, be it Skunk2, AEBS, etc. I thought they need more subastantial modding to be effective? Maybe that's only gor the GSR?
"just go itr intake mani.... you will lose power with a skunk2 on a stock motor. build it first so it deserves a im"
PR3 IM's dont bolt up to the LS head either! and no the AEBS doesnt make IM's for the LS
IF you really really wanted to make it work you could. But when you are done hacking up the gsr manifold to get it to fit then you are stuck with the problem that the ports don't match up. As stated before you will lose power.
ivan93egreppin210
Welding / Fabrication
11
Jun 4, 2009 08:12 PM
crxowner
Feb 22, 2006 12:12 PM
