Question: wire harness installation ..troubles
Old Sep 13, 2004 | 03:13 PM
91EXRMANUAL
Guest
Posts: n/a
Default Question: wire harness installation ..troubles
Is there any diagram for the complete wire harness because i think there is going to be a problem..... i changed the LX wire harness to a complete EXR wire harness with power windows locks etc.. and ecu , i cut corners and sniped some wires to make things easy-er , but i made things worse (duplicate color wires)
i need a diagram..
Modified by 91EXRMANUAL at 4:33 PM 9/13/2004
Old Sep 13, 2004 | 04:04 PM
H2290's Avatar
Default Re: Question: wire harness installation ..troubles (91EXRMANUAL)
Exactly what wires are you talking about and why would you do this? More information is needed to even begin to understand what you are talking about.
Old Sep 13, 2004 | 05:04 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: Question: wire harness installation ..troubles (H2290)
Well , its confusing to you maby ,
I have 3 cars all 4th gens ...the 2 that im working on are going to be made into 1
the car that has no wire harness in the body would be my Grey LX.. it had alot of electrical problems.... i am switching the complete wire harness and everything Else with my EXR , i am also using the power windows off the exr and putting them into my basic LX with manual windows...
Insted of taking all the wires out of the door , i cut the harness at the point where it goes threw the frame into the door by the hinges , and i also cut points that connect around the engine , because i don't want to go threw the engine finding the spider web and removing a ton of parts in the presses, it all went as planned!
BUT
i realized when i was splicing points in the harness that i have duplicate wires that are the same color , and i don't want to mismatch the wires and cross them and f* up the ECU for the exr , all i need is a diagram of the wiring for an exr
the Chilton manual sucks *** for wiring for a novice.. could anyone give me ideas..
Old Sep 13, 2004 | 06:49 PM
91EXRMANUAL
Guest
Posts: n/a
bu bu bu buh benny and the jets....
Old Sep 13, 2004 | 08:04 PM
91EXRMANUAL
Guest
Posts: n/a
If i take some pictures would that help ? , not right now thow im at work
spoolinvtec54
Engine Management and Tuning
11
Feb 13, 2020 09:45 AM
prodjay10
Mar 21, 2017 07:21 AM
soNNy638
Audio / Security / Video
Mar 28, 2010 06:55 AM
sazdasl
Mar 6, 2007 06:36 PM
RTW DC2R
Dec 31, 2004 04:58 PM
