z6 dizzy work on a6?
Old Sep 13, 2004 | 10:17 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default z6 dizzy work on a6?
I did search, anywho...
My friend has a z6 dizzy laying around and mine just went out, will this work on my a6?
Old Sep 13, 2004 | 10:18 AM
crxgator's Avatar
Default Re: z6 dizzy work on a6? (1 point 6)
you would have to cut off one of the legs and convert the distributor harness...
Old Sep 13, 2004 | 10:19 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Default Re: z6 dizzy work on a6? (crxgator)
Another question then, will just the igniter work off the z6 to my a6? This is what I think my true problem is.
Old Sep 13, 2004 | 10:33 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 point 6 &raquo;</TD></TR><TR><TD CLASS="quote">I did search, anywho...
No.
The Z6 distributor and A6 are different internally.
The reluctor wheels inside have a different tooth count. They send a different count of pulses to the ECU. It will run like cheeeiit even if you modded it to fit your head.
Old Sep 13, 2004 | 10:35 AM
crx_88_si's Avatar
Default Re: z6 dizzy work on a6? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
No.
The reluctor wheels inside have a different tooth count. They send a different count of pulses to the ECU. It will run like cheeeiit even if you modded it to fit your head.</TD></TR></TABLE>
correct, 19 vs 21 WILL NOT WORK.
Old Sep 13, 2004 | 12:37 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Default Re: z6 dizzy work on a6? (crx_88_si)
Thanks, good to know. Any info on the igniter?
Old Sep 13, 2004 | 01:17 PM
crxgator's Avatar
how come if you do a mini-me and stay obd0 with a z6 head, you could use the a6 distributor with some modifications, can it only go one way but not the other? i was under the assumption that you could use both since you can use a D15b7 distributor (OBD1 DX) on a D16A6...
Old Sep 13, 2004 | 01:43 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote"> i was under the assumption that you could use both since you can use a D15b7 distributor (OBD1 DX) on a D16A6...</TD></TR></TABLE>
The Z6 has a different bolt/mounting pattern than the other distributors.
you need to stick with an pre OBD distributor if your ECU is pre OBD.
You can use the A6 or the Hf distributor in that case - the DPFI distributors don't have connections to support the 2 additional injectors of MPFI.
If you convert to OBD-1 you can use the other OBD-1 distributors as well. They send the same signal to the ECU as the Z6 distributor does AND they bolt right up to the A6 head correctly without any mods. You can also use the OBD-2 distriubtors, but you have to also have the OBD-2 plugs. No biggy.
I've converted to OBD-1, am running the P28, have a Y8 head (same bolt pattern as the A6), and use an OBD-1 DX distributor. It all works fine.
Old Sep 13, 2004 | 02:37 PM
crxgator's Avatar
I've converted to OBD-1, am running the P28, have a Y8 head (same bolt pattern as the A6), and use an OBD-1 DX distributor. It all works fine.</TD></TR></TABLE>
the dpfi distributor doesnt have anything to do with the fuel injection, it doesnt have the cam angle sensor inside of it like the si/hf does, thats why you can ghetto rig a dx distributor to a zc(nikita)...
if you go obd1 you can not use a z6 distributor on an a6 head, without modifications which would be cut off a leg. the y8 distributor will bolt up to the a6 head along with obd1 non-vtec distributors...like i was saying before when people go with a mini-me and stay obd0 and use a z6 head they can use an a6 distributor on that head if they cut off the leg, so what i dont get is, why can it be the opposite way? isnt it just moving some wires and cutting the leg?
Old Sep 13, 2004 | 04:14 PM
B16 CRX's Avatar
I have a D16A6 dizzy,works well Im me if interested
Old Sep 13, 2004 | 04:29 PM
4drEF's Avatar
Keyboard Humorist
... so what i dont get is, why can it be the opposite way? isnt it just moving some wires and cutting the leg?</TD></TR></TABLE>
Didn't know you could ghetto rig the DX to a ZC? (-well, unless you are using the DX intake manifold and ECU still)
It doesn't have the 2 wires to fire the 2 additional injectors when they need to fire.
You "can" use the A6 head and Z6 distributor.
You have to use a OBD-1 ECU.
You can't just rewire the OBD1 distributor to work with a pre-OBD ECU.
The ECU won't know what to do with the electronic signal being sent to if from the OBD1 distributor which has a different reluctor tooth count than the pre-OBD distributor.
Old Sep 13, 2004 | 04:38 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
So you seem to know your stuff, can i use a z6 igniter in a a6 dizzy?
Old Sep 13, 2004 | 04:55 PM
crxgator's Avatar
ok thats fine, but again the dx distributor has nothing to do with fuel injectors...the extra two wires are for the cam angle sensor...
jawsiiv
Aug 3, 2008 05:11 PM
91integraLSVTEC
Sep 14, 2007 01:02 PM
gsrturbo-ek
16
Jul 24, 2007 09:29 AM
xcchicx
Dec 21, 2003 09:12 PM
egturbo
Dec 11, 2003 06:23 PM
