how to troubleshoot a accord running like it blogged down...
Old Sep 13, 2004 | 08:40 AM
Nufusion1's Avatar
Default how to troubleshoot a accord running like it blogged down...
Hi,
I can figure this one out. My son car all suddent started to run blogged down after you put it in gear...At idlle it runs fine doesn't miss...How when you accerlated you notice that it doesn't have the power run any faster.. I want to troubleshoot...I have check for vac lines that okay... I have check ingition coil with an ohm meter thats okay...I have taken off each of the fuel injector and check for gumming that okay norman wear...I have check ohms on the fuel injector that good. What elese can I do. Oh its an 1986 Accord 3dr f/i...can someone help?
Old Sep 13, 2004 | 08:49 AM
Filthy Focker!'s Avatar
Default Re: how to troubleshoot a accord running like it blogged down... (Nufusion1)
Did this start all of a sudden? Did someone work on the car prior to this?
Usually, if no one has messed with the car prior, it will be 2 things:
1. A fuel restriction
Have you checked if fuel is reaching the injectors? If not, then unplug the fuel line after the fuel filter, and crank the car. You should see the fuel stream out. If not, could be a plugged up fuel filter of something in the line. You may wish, if you have the tools, to check fuel pressure.
2. An exhaust restriction.
Best way to deal with this is to hook up a vaccum guage and see if there is'nt any pressur ebuilding up due to a crushed exhaust pipe (it can happen) or a plugged up cat converter
fs
Old Sep 13, 2004 | 09:07 AM
Nufusion1's Avatar
Default Re: how to troubleshoot a accord running like it blogged down... (filthy_shovel)
I have change the fuel filiter...How ever I have not check for fuel pressure...I guess that would be good start.. I have had catalaty converter replace while back so that should be good. Is there a way to check fuel injector when the car is running? I was also told to check the ingition module? How do I do that?
GREENMOB$TER
Jul 24, 2010 02:51 PM
Christopherian1982
Dec 31, 2008 08:17 AM
MUGEN_EG95
Classic Hondas
Jun 5, 2008 12:50 PM
DevontElan
Feb 14, 2008 03:16 PM
2oh6civic
Mar 30, 2003 07:26 AM
