what are all the sensors on a GS-R intake manifold
having some problems with identifying this particular sensor on my intake manifold, its screwed into the left side on the top its above the map sensor and to the left of the IAT sensor. a small black cylinder is broken off the top of it, its got two vacuum hoses on it and one electrical connector. any help would be greatly appreciated, thanks
EVAP solenoid valve?? That one would have one hose going to the manifold, the other hose going to the EVAP charcoal canister below the battery.
#8 is the one I'm thinking of.
Modified by JimBlake at 3:05 PM 9/13/2004
The top hose nipple wants to be open to the air. That little cap #6 is just a vent so crud doesn't fall inside. It's not even a filter & doesn't seem to do anything else. It just slips down over the hose nipple, & I bet it's pretty cheap even at a dealer. Or just use a couple inches of vacuum hose doubled over so it points downwards.
Hondatypr636
Aug 22, 2011 11:19 AM
