Quick LS Build Question
Old Sep 13, 2004 | 07:20 AM
brnzbuddha's Avatar
Default Quick LS Build Question
I search around and some people were recommending trying to use OEM pistons in the LS blocks to raise compression. I was wondering if Civic Type R pistons would work in my b18a using the factory rods. Would any machining need to be done?
Thanks guys!
Old Sep 13, 2004 | 10:11 AM
hybrid_vtec's Avatar
Default Re: Quick LS Build Question (brnzbuddha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brnzbuddha &raquo;</TD></TR><TR><TD CLASS="quote">I search around and some people were recommending trying to use OEM pistons in the LS blocks to raise compression. I was wondering if Civic Type R pistons would work in my b18a using the factory rods. Would any machining need to be done?
Thanks guys!</TD></TR></TABLE>
Yes CTR's require machining to LS rods to make them fit! P30 Pistons are a good choice too and require no machining! The choice is up to you though depending on your setup and goals!
Old Sep 13, 2004 | 02:31 PM
brnzbuddha's Avatar
Default Re: Quick LS Build Question (hybrid_vtec)
Well then, the next question. Where can I get p30 pistons and rings? What motor did they come out of?
Old Sep 13, 2004 | 03:32 PM
brnzbuddha's Avatar
Nevermind, found pistons and much more! Thanks guys!
Beasting EF22
Jan 14, 2012 05:48 AM
hondapimp125
Oct 13, 2009 10:55 AM
stoney0078
Jan 30, 2009 06:08 AM
queda
12
Nov 1, 2007 10:05 PM
smnowell
Oct 11, 2002 01:10 PM
