which shift linkage is best for a jdm itr swap into a 95 auto-manual civic - LS, GSR, or ITR?
Old Sep 13, 2004 | 05:06 AM
JinDIESEL's Avatar
Default which shift linkage is best for a jdm itr swap into a 95 auto-manual civic - LS, GSR, or ITR?
a 97 JDM ITR engine is dropped onto a 95 auto-manual converted civic coupe.
which shift linkage is best for function and oem shift feeling with a skunk 2 double bend shifter? an integra LS, GSR, or ITR shift linkage? the ITR shift linkage that came with my engine is bent too much out of range, so i need to go to the junk yard to get a replacement.
PLEASE HELP US. the swap is 95% done. all they need to do is this, plug the AC back in, and cleaning up the center console and the wiring.
thanks a whole lot for your responses.
Old Sep 13, 2004 | 07:52 AM
chad's Avatar
Moderator
Default Re: which shift linkage is best for a jdm itr swap into a 95 auto-manual civic - LS, GSR, or ITR? (J
LS-GSR-ITR are all BASICALLY the same....you will get no better performance out of one or the other....
Old Sep 13, 2004 | 11:46 AM
cjames235's Avatar
get the ITR or 99SI i would say...... even though they are all BASICALLY the same i think the gsr is a lil different in the bends
tfeagley
Jun 30, 2009 05:48 PM
.:JEROME:.
Sep 12, 2005 07:16 PM
JinDIESEL
Sep 13, 2004 05:22 AM
JinDIESEL
Sep 12, 2004 04:31 PM
