a JDM ITR swap to a 95 civic coupe, which shift linkage is best in giving the oem feel? LS, GSR, or
Old Sep 13, 2004 | 04:58 AM
JinDIESEL's Avatar
Default which shift linkage
a 97 JDM ITR engine is dropped onto a 95 auto-manual converted civic coupe.
which shift linkage is best for function and oem shift feeling with a skunk 2 double bend shifter? an integra LS, GSR, or ITR shift linkage? the ITR shift linkage that came with my engine is bent too much out of range, so i need to go to the junk yard to get a replacement.
PLEASE HELP. the swap is 95% done. all they need to do is this, plug the AC back in, and cleaning up the center console and the wiring.
thanks a whole lot for your responses.
Modified by JinDIESEL at 9:09 AM 9/13/2004
Old Sep 13, 2004 | 05:06 AM
EK-Chris's Avatar
Default Re: a JDM ITR swap to a 95 civic coupe, which shift linkage is best in giving the oem feel? LS, GSR,
LS/GSR/R/Si has the same length linkage. The JDM linkage has a gold color while the USDM linkage is black. None will really change how it feels with a shifter, unless you use polyurethane shifter bushings.
Old Sep 13, 2004 | 05:22 AM
JinDIESEL's Avatar
anymore suggestions, guys? please help us out... we need opinions so we can get this swap done and running today.
HGL1668
Nov 28, 2006 10:23 PM
JinDIESEL
Sep 12, 2004 04:31 PM
