Help Breaking up problem
Old Sep 12, 2004 | 08:44 PM
Reef188's Avatar
Default Help Breaking up problem
i have a 92 hatch and swapped the stock blown motor for another stock motor... the motor will start and idle fine. but when you accelerate the car falls on its face. i tested the tps, changed the fuel filter, changed the fuel pump, the distributor, checked the timing, and put new spark plugs...anyone have any idea what it could be...otherwise i'm gonna rip this motor out and throw an ls in it. Thanks
Old Sep 12, 2004 | 08:49 PM
JDMlyfestyle's Avatar
does it have the EX or CX tranny? cause the CX tranny is horrible
Old Sep 12, 2004 | 08:51 PM
Reef188's Avatar
Default Re: (JDMlyfestyle)
well actually dx...but it does it when its sitting also it doesn't have to be moving...it sounds like its not getting enough fuel but smeels like its running rich.
Old Sep 12, 2004 | 08:57 PM
Could be a blown headgasket. that would make it run like ****. done a leakdown/compression test?
Old Sep 12, 2004 | 09:07 PM
Reef188's Avatar
yup did a compression test...came out good according the what the manual wants for compression.....it idles good put then when u hit about 2000-2500 rpm it just falls on its face...
Old Sep 13, 2004 | 08:45 PM
Reef188's Avatar
Default Re: (reef188@aol.com)
Old Sep 13, 2004 | 09:26 PM
bushfreakz's Avatar
timing
Old Sep 13, 2004 | 09:31 PM
MassScene's Avatar
Default Re: Help Breaking up problem (reef188@aol.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reef188@aol.com &raquo;</TD></TR><TR><TD CLASS="quote">otherwise i'm gonna rip this motor out and throw an ls in it. Thanks</TD></TR></TABLE> PROBLEM SOLVED
Old Sep 14, 2004 | 08:58 PM
Reef188's Avatar
civichatch201
Sep 30, 2009 07:12 PM
boostedtsi
Oct 26, 2008 09:01 PM
BiG_DeE
11
Feb 1, 2008 02:08 PM
Chillin94hatch
Jul 22, 2004 01:59 PM
One Bad GeeSeeR
Aug 10, 2002 08:01 PM
