signs of a failing vtec solenoid maybe?
are these signs of a stupid car or a failin vtec solenoid. this is the 2nd time this has happend in the past 2 months. i'll get a check engine light for a code 22 i believe it is...malfunctioning vtec system. i unplug the plugs on the vtec solenoid, clean them out, reset the computer and memory and presto...i have vtec again and no more code. is my solenoid faling or are my plugs just gettin that dirty that fast?
hmm, i dont like the sounds of that...i did check my oil, its fine..i then reset the ecu and the code went away again and it runs fine once again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">well, if your oil pressure is fine, then its most likely your vtec pressure switch.
vtec needs 60+ psi to work properly</TD></TR></TABLE>
where did u get this info?
when i check oil pressure to the head 4 vtec i know its under 60psi but don t remember the exact number i think it was 48 or so.
if u check 4 flow (the plug in front on top of the headers)
its only about 25psi when vtec is engage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cylinder »</TD></TR><TR><TD CLASS="quote">
its only about 25psi when vtec is engage </TD></TR></TABLE>
the plug by the vtec sol. is to test vtec oil pressure.
at 5k rpms +, pressure should be 60 or more psi(with vtec engaged)
if you check that when vtec is disengaged you should get a low reading but not below 7psi.
94wip
12
Jun 20, 2024 07:23 PM
BobGnarly
May 23, 2004 05:28 PM
