Help.... Washed car and now it won't start
Could someone please help...
I have a 92 teg gs and 3 days ago I found oil in my spark plugs and wires. The car starts all the time but just today I washed my car and now it doesn't want to start. I turn the key but it struggles to start sounds like the fuel pump is working but it just won't start.
Thanks
Thanks
u should replace the O rings that the valve cover sits on... if they arent sealing good it will cause oil to leak into your spark plug holes...
^^^ i agree with that guy. remove ur valve cover and replace ur spark plug O-rings. replace ur spark plugs and wires as well. they might be shot
did you spray your engine bay? and did u cover ur distrib cap? if water got inside then it won't start or will run like crap.. take off the cap and dry up the connections
I'll try that!
My car started this morning but I'm going to get it fixed as aoon as possible.
Would the car not start if I have an AEM cold air intake and the filter got wet.
Please let me know, would appreciate all the feedback I could get so I can prevent this from happening again.
Thanks
Thanks
kodyhalkyard
26
Oct 26, 2011 06:51 PM
lilmisshonda
Jul 2, 2008 09:40 PM
dailydriven91ex
Jul 19, 2004 06:50 PM
