replacing brakepads need help (tried search)
well i tried to search for brake pad and front brake pad on the site, couldnt find none with pictures or anything that shows me how to replace it..well i thought i knew cause i've seen it done 1-2 times , well one time..thought it was quite easy so decided to do it myself, well i bought some PFC-CARBON-METALIC BRAKE PAD/SHOE - FRONT from autozone with lifetime warranty, not sure if they're that great and i also bought the grease, anyone know a site where shows pictures with details etc? i looked on the other side of caliper, noticed htere's around 5 bolts, 2 17mm i believe, and 2 12mm not sure and one is brake fluid line? i know u'd need a c-clamp to push the pistons back in, and i believe put grease on back of pads? i need some pictures so i can be 100% sure on which bolts etc thanks
P.S. sorry for long post, if u dont want to read i need a website that shows diy brake pad installation for front 94+ integra with pictures
http://www.team-integra.net/se...D=373 there you go! good luck! btw, you shouldnt be messing w/your brake lines unless you're gonna bleed your brakes....you dont need to mess w/them to just change your pads!
JDM Dylan
10
Mar 9, 2008 05:31 PM
dochmees
Dec 10, 2002 05:25 AM
