h22a Beyond 8,000rpm's
Old Sep 12, 2004 | 11:42 AM
popRAWvtec's Avatar
Default h22a Beyond 8,000rpm's
anyone with a h22 reving pass 8k?
Old Sep 12, 2004 | 12:03 PM
LudeyKrus's Avatar
I know someone w/ the Jun head and ECU that CAN, but she doesn't because it just doesn't make any power up there.
Old Sep 12, 2004 | 12:28 PM
popRAWvtec's Avatar
Default Re: h22a Beyond 8,000rpm's (popRAWvtec)
why not? doesn't the jun camshafts help. Do you know what rpm limiter hit's
Modified by popRAWvtec at 1:41 PM 9/12/2004
Modified by popRAWvtec at 1:42 PM 9/12/2004
Old Sep 12, 2004 | 01:05 PM
LudeyKrus's Avatar
Yes, the Jun cams help, but there's still no point. It stops making power before then, and revving it any higher is just stressing your motor out and making you slower.
You need some BIGASS cams and some good portwork to make power up that high.
Old Sep 12, 2004 | 02:11 PM
juicedh22's Avatar
Default Re: (LudeyKrus)
I can rev my all-motor built h22 to about 8300 rpms, i used to when racing, but there isnt much point, even on the dyno i have found i dont make any more hp after about 7700-7800 rpm, so about 7900-8000 is where i shift when racing...
Old Sep 12, 2004 | 03:15 PM
WillsH22Accord's Avatar
well ive had 2 h22s, and my first one would pull HARD from vtec engagement until 8200 rpms. The ecu was chipped with spoon specs. Stock block and head. fuel cut at 8700
Old Sep 12, 2004 | 03:30 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: (WillsH22Accord)
that would be ridiculous. the h22 simply isn't designed like a b series motor is. It doesn't make that much power up top. It's great for mid range and the low range is pretty good too but anything past 7200 is a waste as you'd probably blow your oil pump or heat up your cylinder walls too much.
Old Sep 12, 2004 | 04:36 PM
BlownVR's Avatar
Default Re: (juicedh22)
I used to take mine to 8200 with chipped ecu, i dont know if it made power after 7200 but it still wnt up that high and never blew
Old Sep 12, 2004 | 05:48 PM
Kal's Avatar
Kal
why? Would be useless unless you ran a race car and boost.
Old Sep 12, 2004 | 06:06 PM
Shakes's Avatar
space cadet
Default Re: h22a Beyond 8,000rpm's (Kal)
what ever happened to the 8000 RPM crank crack. i seem to remember that being the magical number for snapping cranks a year or two ago.
Old Sep 12, 2004 | 06:37 PM
uncle's Avatar
Default Re: h22a Beyond 8,000rpm's (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">what ever happened to the 8000 RPM crank crack. i seem to remember that being the magical number for snapping cranks a year or two ago. </TD></TR></TABLE>
Bounced mine off the 8500 rev limiter twice and no problems. *crosses fingers*
Old Sep 12, 2004 | 06:58 PM
popRAWvtec's Avatar
Default Re: h22a Beyond 8,000rpm's (uncle)
what type of aftermarket cams. would be good to hold the power pass 8krpm's? any good ones in mind.
Old Sep 12, 2004 | 07:11 PM
Matgallis's Avatar
what's the big deal with 8k revs? It doesn't make you "cool"
Old Sep 12, 2004 | 07:46 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: h22a Beyond 8,000rpm's (Matgallis)
next there gona want to rev past 10grand just cuz the honda motorcycles do it
Old Sep 13, 2004 | 04:59 AM
LudeyKrus's Avatar
That may be the H23 crank you're thinkin about.
Old Sep 13, 2004 | 05:11 AM
JDMCLUDE's Avatar
I have taken mine to 8 before and it really doesn't gain that much more power. I would like to find a cheap alternative to getting rid of my JDM 120mph Fuel cut off!!!? Any suggestions other than rev speed meters and expensive electronics? Any hard wiring suggestions to trick the ECU or anything?
Old Sep 13, 2004 | 05:36 AM
Matgallis's Avatar
Default Re: (JDMCLUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCLUDE &raquo;</TD></TR><TR><TD CLASS="quote">I would like to find a cheap alternative to getting rid of my JDM 120mph Fuel cut off!!!? </TD></TR></TABLE>Unless you're running 12's no need to go past 120mph.... Stupid and dangerous, leave it at the strip.
Old Sep 13, 2004 | 09:30 AM
PirateMcFred's Avatar
Default Re: h22a Beyond 8,000rpm's (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">next there gona want to rev past 10grand just cuz the honda motorcycles do it </TD></TR></TABLE>
CBR600rr goes to 15,000 rpm. I would love to see footage of the aftermath of an H22 hitting 15Krpm. lol
Pirate
Old Sep 13, 2004 | 09:52 AM
98TypeSH's Avatar
Default Re: h22a Beyond 8,000rpm's (PirateMcFred)
My jun cams make power up to 8K plus, i just choose not to take it any higher because i got a stock bottom end. We dynoed and cut all 11 of my runs off at 8K - 8300K The car pulls like no other, and just waiting to get my skunk 2 mani on (i really want to dyno this damn thing) and fix my CYP.
Old Sep 13, 2004 | 09:55 AM
popRAWvtec's Avatar
Default Re: h22a Beyond 8,000rpm's (98TypeSH)
how does skunk2 stage 2 cams. sound?
Old Sep 13, 2004 | 10:31 AM
well in my first motor, i made power up to at least 8000 but in my new motor, i start to lose power at about 7300
Old Sep 13, 2004 | 11:18 AM
Slipknt777's Avatar
Im running Gude cams that are capable of 8600 rpms...but i shift at the stock vtec redline....there is not much of a power gain after that.
Old Sep 13, 2004 | 12:18 PM
Daniel M.'s Avatar
I have a chiped ECU with rev limiter at 8200rpm.
The engine pulls well untill 7800rpm, over it's useless to go.
I just get over that point in the first gears to get to good power point after I shift.
Old Sep 13, 2004 | 01:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popRAWvtec &raquo;</TD></TR><TR><TD CLASS="quote">how does skunk2 stage 2 cams. sound? </TD></TR></TABLE>
Sounds expensive. And from the dynos I have seen you can do just as well from a set of Crower stage 2's which are a couple hundred cheaper.
Pirate
Old Sep 13, 2004 | 02:35 PM
precord96's Avatar
My motor is a Jdm H22A with a stock block; Jun cams+valvetrain, Prospeed header and mine keeps making power at my 8411rpm cutoff. Always rev it up past 8k rpms on the street, no problems in over 3 yrs revving up that high. Here's a dyno...... I know most of you are gonna try and flame me with my dyno results, like what mods i have and blah-blah, but here goes
Modified by precord96 at 11:48 PM 9/13/2004
