can i use type r crank in b20 block??
Old Sep 12, 2004 | 02:32 AM
jdmitrhatch's Avatar
Default can i use type r crank in b20 block??
i have type r crank, rods/pistons...what can i use in b20 block...i know i cant use the pistons, but can i use the rods?...is it the same stroke?
Old Sep 12, 2004 | 04:47 AM
asubennett's Avatar
Default Re: can i use type r crank in b20 block?? (jdmitrhatch)
You can use the rods if you use the crank. And yes you can use the crank.
Old Sep 12, 2004 | 07:12 AM
b19coupe's Avatar
B20 stroke is 89mm and the rods are shorter. Type-R crank is 87.2mm and the rods are longer. Use the matching crank and rods ; you will be fine.
Old Sep 12, 2004 | 10:08 AM
Default Re: can i use type r crank in b20 block?? (Manuel)
so your saying i can use the type r crank and rods in the b20 and i will have the stock b20 stroke?...i can still use b20 stock bore pistons and get the same deck height?
Old Sep 12, 2004 | 11:02 AM
97L-esVeeTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitrhatch &raquo;</TD></TR><TR><TD CLASS="quote">so your saying i can use the type r crank and rods in the b20 and i will have the stock b20 stroke?...i can still use b20 stock bore pistons and get the same deck height?</TD></TR></TABLE>
no. your stroke will decrease from 89mm to 87.2, you can use the type r crank and rods, essentially you'll have a bored out gsr/type r with shitty stock b20 sleeves.
Old Sep 12, 2004 | 03:44 PM
jwaked's Avatar
Default Re: can i use type r crank in b20 block?? (97L-esVeeTeg)
You will end up close to 2000 c. I think is 197x. Thats what I did and have. Close enough.
Old Sep 12, 2004 | 04:14 PM
HondaMaster200's Avatar
Default Re: can i use type r crank in b20 block?? (jwaked)
i would use the itr crank, rods and pistons in a gsr block
Old Sep 12, 2004 | 06:06 PM
rodimus's Avatar
Default Re: can i use type r crank in b20 block?? (HondaMaster200)
you can use a type r or gsr crank in the b20 block.
and if you didn't know, the ls crank and b20 crank are the same shizz.
if you use a type r or gsr crank, use type r or gsr rods, or aftermarket rods of equal length unless you're getting custom sized rods of course.
use the b20z pistons if you can.
ask omniman or search for his post..his setup is similar to what you are asking of.
Old Nov 2, 2004 | 05:42 PM
justink4's Avatar
scroll all the way down to the bottom
http://www.todaracing.com/prod....html
I don't know if this helps or not...hope it does
20
Apr 11, 2013 07:39 AM
dannyneedshelp
Oct 15, 2008 04:22 PM
little2fast4u
Aug 2, 2008 06:46 PM
B18C2_sedan
25
Feb 1, 2004 05:19 PM
vtec_racer_2kgsr
Nov 19, 2003 07:36 PM
