need help with crank
hey this is mysecond post, so hi, well my question is would it be easier to get my crank balanced or to just buy a new one from crower or scat. btw i have a 94 rs teg. hoping to go lsvtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teg_RS »</TD></TR><TR><TD CLASS="quote">hey this is mysecond post, so hi, well my question is would it be easier to get my crank balanced or to just buy a new one from crower or scat. btw i have a 94 rs teg. hoping to go lsvtec</TD></TR></TABLE>
ive heard of a scat crank thats was advertised 89mm stroke but when it was double checked by the engine builder its was a little bit bigger 89.2ish
that was only on one journal, so it wasnt confirmed that all of them were the same or way off from each other
it may or may not be a problem depending on how tight you are running things
just throwing it out there for you to know
balancing a stock crank is a routine procedure though, i dont see why you would have problems, just make sure this isnt the first honda crank being done by the person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94teg_RS »</TD></TR><TR><TD CLASS="quote">so with the lscrank balanced would i be able to rev it to 9k</TD></TR></TABLE>
it can be done but dont make it a habit of doing down every street
ls cranks will rev 9500+ if properly assembled
stay with ls crank. Get your bottom ennd balanced and vtec oil pump and your good to go. I rev mine to 9 pretty often and its still good. Make sure your pasti gauge your mains and rods.
mrrugsr
29
Oct 20, 2007 07:44 AM
carboy_honda
19
Jan 6, 2007 04:59 PM
