accord 90 loss power, RPM are Crazy!
Old Sep 11, 2004 | 05:42 PM
anorzaga's Avatar
Default accord 90 loss power, RPM are Crazy!
Hi Everybody!, i have a problem, my accord 90 lose power when i turn on te a/c When I am doing a stop and i tray to go on, after a few seconds recovers the force and I continue as if nothing was happening (For this I need to accelerate up to the bottom).
On the other hand when I go in highway after the 2500 rpm the indicator (tachometer) becomes crazy, but I am not feel that the car fails, what to be the problem?
what can i do to find the solution?
Thanks!
Sorry for my english...
Old Sep 11, 2004 | 06:16 PM
TxTuner
Guest
Posts: n/a
Default Re: accord 90 loss power, RPM are Crazy! (anorzaga)
I have no idea what you're trying to say but some loss of power when you turn on the a/c is normal
Old Sep 11, 2004 | 07:25 PM
ivanson's Avatar
Your in luck! I had that same problem too. It could be the Distributor. I had this problem untill the car died and never wanted to start on me again. After i had install the new distributor it worked fine. But first test your distributor it might just need a core, but on mine it was the whole distributor.
Old Sep 11, 2004 | 08:05 PM
BlazeTeck2000's Avatar
Default Re: accord 90 loss power, RPM are Crazy! (ivanson)
one thing tho is that a/c make the car lose power when there on and makes you lose gas milege 2
Old Sep 11, 2004 | 08:14 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anorzaga &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry for my english...</TD></TR></TABLE>
No problem man, it doesnt look like you are from the US
It is completely normal for you to drop some power when you turn you A/C on.. Reason behind it is, your a/c compressor is belt driven thus using power from the car when it is turned on.
Old Sep 12, 2004 | 06:58 AM
SearchBeforeUPost!'s Avatar
Default Re: accord 90 loss power, RPM are Crazy! (bagged93accord)
crazy tach means the ignitor in your distributor is on the way out.
bairwin
Aug 6, 2012 08:09 AM
hondaflipper
Classic Hondas
May 9, 2011 04:01 AM
KACKMASTAH
Jun 30, 2007 06:32 PM
JforJonathan
Dec 12, 2004 03:16 PM
1 2 NV
May 22, 2004 11:35 AM
