removing transmission?
Do I NEED to remove the driveshafts and intermediate shaft to remove my tranny and replace the clutch?
because ive removed every bolt and everything else except for the driveshafts and intermedite shafts, and the tranny doesnt want to come out.
I followed every step in the helms and the tranny still wont come out.
thanks
-Charlie
thanks
-Charlie
yup gotta remove them. did u remove the lines attached to the tranny also? also your gonna have to pry it off a lil bit because there's dowel pics holding it on.
when I removed my tranny I didn't even bother with the big axle nuts. I just disconnected the steering knucle from the lower control arm and the damper fork, then grabbed from the inside CV joint and pulled away from the car, then I tied it aside with zip ties, on the driver side just loosen the bolts on the Intermediate shaft, and do as the other side, u don't need to completely remove or disconnect the intermediate shaft, just again pull it aside and tie the spindle with some zip ties.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salvageland »</TD></TR><TR><TD CLASS="quote">when I removed my tranny I didn't even bother with the big axle nuts. I just disconnected the steering knucle from the lower control arm and the damper fork, then grabbed from the inside CV joint and pulled away from the car, then I tied it aside with zip ties, on the driver side just loosen the bolts on the Intermediate shaft, and do as the other side, u don't need to completely remove or disconnect the intermediate shaft, just again pull it aside and tie the spindle with some zip ties. </TD></TR></TABLE>
thanks man, Im gonna go try it right now!
Ricey McRicerton
33
Jul 29, 2012 06:46 AM
0ptimus prime
Jul 17, 2004 11:17 PM
