Whats the word on the GX20
Old Sep 11, 2004 | 01:29 PM
Galaxy Si's Avatar
Default Whats the word on the GX20
I just got finished watching a car show, and they interviewed a guy that works for a honda company. he was talking about this new crate motorthat is made for hondas. he said the block last longer than anyother honda block, comes with 270 HP. Costs over $10,000. my question is, what Honda are these motors made for?
Old Sep 11, 2004 | 02:03 PM
egryda's Avatar
Default Re: Whats the word on the GX20 (B18C1 Del Sol soon)
are you talking about "the beast", made by mr gasket?
Old Sep 11, 2004 | 02:21 PM
SOHC4life 96's Avatar
Default Re: Whats the word on the GX20 (egryda)
You just finished watching Car and Driver on Spike TV didnt you? I just saw the same thing. The producers were at Hot Import Nights and they looked at the GX20, they didnt say who made it or when it was going to be on the market. I think that episode was about 3 or 4 months old.....
JDMisGOOD's Avatar
yeah thats the "BEAST" $8,995.00
SPECS:
Bore:84mm
Stroke:89mm
Rod Length:140.8mm
R/S Ratio:1.58:1
Compression Ratio:11:5:1
Intake Valve Size:34mm
Exhaust Valve Size:28mm
BHP:270@7800 RPM (this is an engine dyno figure)
Peak Torque:185 ft-lbs@6000 RPM
Camshaft Spec:Lift/Duration: IN. 0.485,252,EX. 0.466,262
Cam Gears:Unorthodox Racing (Ultra T)
ARP: Head Studs, ARP Rod Bolts Baffled Performance Oil Pan
Fuel:Quality 92 or higher octane (pump gas)
Must use modified or aftermarket ECU. Engine is cold tested from the factory, for cylinder leak down, proper oil pressure, coolant and oil leaks. Complete with new factory oil pump, water pump, timing belt and covers, hardware, and VTEC solenoids. Timing is factory set. Assembled with precision at Performance Assembly Solutions.
Engine has produced 13.4 second E/T's in a 2600lb car, and still achieves 30mpg. Wiseco forged pistons. Oliver E4340 Chrome Moly Rods. Eagle Forged 4340 crankshaft. Mr.Gasket MLS head gasket. Also available in a short block version and Low Compression Turbo Version.
Old Sep 11, 2004 | 02:23 PM
Ricey McRicerton's Avatar
Default Re: Whats the word on the GX20 (JDMisGOOD)
9k and it STILL makes next to no torque.
Old Sep 11, 2004 | 02:24 PM
JDMisGOOD's Avatar
Default Re: Whats the word on the GX20 (Ricey McRicerton)
but it carries a 12month or 12,000 mile warranty!
Damn, you can get a K20a swap for just about that much..... I would rather have a K series swap over that (any K series) anyday. Just my .02.
Old Sep 11, 2004 | 02:25 PM
Kyles ej1's Avatar
for that much could u like turbo a b18c and get more hp n tq?
JDMisGOOD's Avatar
Default Re: Whats the word on the GX20 (egcoupe)
but u dont get a warranty... thats what this motor has goin for it!
Old Sep 11, 2004 | 02:26 PM
Kyles ej1's Avatar
damn i always 4get bout the k20
Default Re: Whats the word on the GX20 (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">Damn, you can get a K20a swap for just about that much..... I would rather have a K series swap over that (any K series) anyday. Just my .02.</TD></TR></TABLE>
And you would pick the K swap why?
Old Sep 11, 2004 | 02:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe &raquo;</TD></TR><TR><TD CLASS="quote">damn i always 4get bout the k20</TD></TR></TABLE>
Everyone does All the more reason to get one *coughmyfutureplanscough*
Old Sep 11, 2004 | 02:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
And you would pick the K swap why?</TD></TR></TABLE>
*shrugs shoulders* I dunno, be different. Not to many people have them.
Old Sep 11, 2004 | 02:29 PM
*shrugs shoulders* I dunno, be different. Not to many people have them.</TD></TR></TABLE>
I doubt too many people have that either. Plus youd be up 70 hp on a US spec K20a and wouldn't have all the headaches of a K series swap....
Old Sep 11, 2004 | 02:31 PM
JDMisGOOD's Avatar
I doubt too many people have that either. Plus youd be up 70 hp on a US spec K20a and wouldn't have all the headaches of a K series swap....</TD></TR></TABLE>
w3rd!
personally i think its a badass deal for a fully assembled warrantied engine...
Old Sep 11, 2004 | 02:32 PM
I see where your coming from. Thanks to you I now have two options! What a helper outter! lol j/k
Old Sep 11, 2004 | 02:42 PM
99CivicExCoupe's Avatar
this has been discussed to death lol, it comes down to this, for 9g's u get the same you could...if not more...out your own project, but u just get the 12mth warranty,
Old Sep 11, 2004 | 02:49 PM
Kyles ej1's Avatar
is it just the block n head or does it come as a complete swap?
Old Sep 11, 2004 | 02:57 PM
Pretty sure it's a complete engine. I just realized you need a transmission too though. There goes another 1000 on it.
Just read you can run a 13.4 in a 2600 lb car. I'd be willing to bet you can run much lower times than that with it. Hell, an ITR in a 2600 lb car can run mid 13s with a decent driver.
Old Sep 11, 2004 | 03:01 PM
Kyles ej1's Avatar
well i knoe my friend put 10k into a n/a b18c1 including the swap n install and he was running 13.5, so i guess its worth it if u got the $ except gas is gonna be a bitch
Old Sep 11, 2004 | 03:02 PM
SirRevvs's Avatar
what's the displacement of this engine?
Old Sep 11, 2004 | 03:08 PM
nojoke's Avatar
1.974 liters
Old Sep 11, 2004 | 03:09 PM
SirRevvs's Avatar
Default Re: (nojoke)
so it's a 2.0
Old Sep 11, 2004 | 03:31 PM
Galaxy Si's Avatar
i think its pretty badass. 270hp at 7800 rpms and 185ft-lbs at 6000 rpms, you can't beat that even with a n/a K20. matter of fact, i did just finish watching it on Spike. Gotta love the car shows
Modified by B18C1 Del Sol soon at 6:56 PM 9/11/2004
Old Sep 11, 2004 | 03:34 PM
Kyles ej1's Avatar
if i had the $ id buy it
