searched found then lost/d6 jumped to a4 then to vtec silenoid
Old Sep 11, 2004 | 12:24 PM
aziz93's Avatar
Default searched found then lost/d6 jumped to a4 then to vtec solenoid
need to know if that is how it goes. i got a 93 dx coupe with lsvtec, jdm head and 1 wire vtec, no pressure switch just 1 wire to the vtec solenoid. Now what i need to know is do you run the 1 wire (vtec solenoid wire) to a4 on the ecu and then use a jumper wire to connect d6 to a4. I know there is the perfect post out there cause i seen it a few weeks ago but computer froze and i never got to save it and i just searched for 2 hours and cant find it pls help
Old Sep 11, 2004 | 01:54 PM
aziz93's Avatar
Default Re: searched found then lost/d6 jumped to a4 then to vtec solenoid (aziz93)
ttt
Old Sep 11, 2004 | 02:32 PM
aziz93's Avatar
just seen another post and it said i should just ground the d6 pin coming out of the ecu and run the a4 pin to the vtec solenoid dont know and dont wanna find out its not right the hard way need help....thanks....David
Old Sep 11, 2004 | 04:52 PM
aziz93's Avatar
t da word
Old Sep 12, 2004 | 05:48 AM
aziz93's Avatar
ladeda
digital sol
Oct 30, 2004 12:07 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
mr. carpenter
May 5, 2004 09:47 PM
eazye5591
Dec 27, 2003 03:22 AM
