will seafoam work on 87 crx?
Old Sep 11, 2004 | 11:47 AM
Dc2 Powered's Avatar
Default will seafoam work on 87 crx?
will a seafoam work on a 87 crx non FI. if so where would uput it
Old Sep 11, 2004 | 01:33 PM
Default Re: will seafoam work on 87 crx? (Dc2 Powered)
well? its a 1987 CRX HF
Old Sep 11, 2004 | 02:04 PM
vtecn8ive's Avatar
(carburetor) Take out the air filter and pour it in there. Seafoam can be used in your gas tank, oil, and fuel.
Old Sep 11, 2004 | 02:07 PM
RCautoworks's Avatar
Default Re: will seafoam work on 87 crx? (vtecn8ive)
Just make sure you do know the effects, I have seen some bad effects from it like blown head gaskets and such.
Old Sep 11, 2004 | 02:34 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: will seafoam work on 87 crx? (90blackcrx)
What are you trying to do with the seafoam?
Old Sep 11, 2004 | 02:48 PM
seafoam is supposd to clean the carbon build up in your engine right? well a friend of mine hads a 87crx hf and wanted to know where woul dge put the seafoam
Old Sep 11, 2004 | 09:30 PM
Default Re: (Dc2 Powered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2 Powered &raquo;</TD></TR><TR><TD CLASS="quote">seafoam is supposd to clean the carbon build up in your engine right? well a friend of mine hads a 87crx hf and wanted to know where woul dge put the seafoam</TD></TR></TABLE>
Yes correct, but some of the effects can be pretty bad. Get a water bottle, turn it so its spraying the mist pattern. Have your friend old the engine at about 1,500 ( you can increase this but just make sure its not idling ) and spray the water in your engine, not a lot but about 2 sprays every now and then. What does water create when it becomes hot enough ? Steam, so your steam cleaning the inside of the engine.
DamnThatsRexy
Nov 20, 2023 11:33 AM
glennxx1
10
Jun 8, 2008 05:36 PM
thunderlips
Apr 19, 2008 07:16 PM
1990hondacrxhf
17
May 5, 2007 05:02 PM
EFMAN
13
Jan 16, 2006 02:13 PM
