Please Help! CAS problem!
Old Sep 11, 2004 | 10:38 AM
EG6 SiR's Avatar
Default Please Help! CAS problem!
Hey H-T,
I did a timing belt job on a 2001 Civic about 5 months ago and when I was done I got a CAS CEL and it was putting me in Limp Mode (safe mode). I reset the ECU and all was good untill today. I got the same code and it put me in safe mode again. What would cause this code to pop up again after 5 months of no problems? Could the sensor go bad after 95,000 miles? I dont think it is the timing because it ran good for 5 months. Also this is an OBD-IIb and the Crank Angle Sensor(CAS) is located at the crank. Please Help it would be greatly appreciated! Thanks!
Do you think I should just reset the ECU again? Thanks!
Old Sep 11, 2004 | 11:12 AM
EG6 SiR's Avatar
Default Re: Please Help! CAS problem! (EG6 SiR)
ttt
Old Sep 11, 2004 | 01:34 PM
EG6 SiR's Avatar
Nobody knows?! I searched and I didnt find any topics on my problem. At least not for a 2001 civic. Someone give me some input or if you need more information let me know. Thanks!
88turdbucket
Mar 31, 2011 04:37 PM
jerzey908
Oct 20, 2010 07:25 AM
soloIIjdmcrx
Dec 4, 2006 05:51 PM
B00ST2nR
Sep 17, 2002 09:12 AM
