stripping valve cover a bad idea?
Old Sep 11, 2004 | 09:59 AM
FakeJDMEF8's Avatar
Default stripping valve cover a bad idea?
i have a B16a and its valve cover has been painted red and looks really shitty. i was talking to my buddy at honda, hes an eg fanatic, and said if i strip it down to just the aluminum it might crack. if a rock somehow makes it through my front bumper and hits it it will crack possibly. he said its a protectice porceleon and rubber covering for protection...any thoughts on this? any pictures of a bare aluminum valve covers? any suggestions on how to remove it; tips rather? (i know to paint on aircraft stripper and let it sit, and then just wash it off?) thanks guys
Old Sep 11, 2004 | 10:09 AM
Rostr02's Avatar
Default Re: stripping valve cover a bad idea? (FakeJDMEF8)
I am doing mine and see no problems with it. Strip it with air craft remover then clean it off with laquer thinner before u paint and u should be ok. Just dont get the aircraft remover on you hands unless you want second degree chemical burns. I can vouch for being an idiot.
Old Sep 11, 2004 | 10:13 AM
Reelizmpro's Avatar
The chances of a rock hitting and cracking the valve cover is slim to none. First of all, the valve cover sits higher than the bumper openings and obviously is horizontal. Without the coating, the valve cover dissipates more heat faster.
Old Sep 11, 2004 | 10:18 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: stripping valve cover a bad idea? (Reelizmpro)
Mine is stripped... There is no way its going to crack..
Old Sep 11, 2004 | 10:22 AM
K20betty's Avatar
I know from experience that it does not hurt the valve cover when you strip it .
Old Sep 11, 2004 | 10:37 AM
krazie1's Avatar
BANNED
Default Re: stripping valve cover a bad idea? (sizc)
I got mine also done like that
and it is my dyno valve cover as it has the moon cut outs for the cam gears
Old Sep 11, 2004 | 11:17 AM
SoulSurfer's Avatar
Default Re: stripping valve cover a bad idea? (krazie1)
It's paint...it's not going to stop a rock from damaging something. You'll be fine.
Old Sep 11, 2004 | 12:06 PM
kid-honda's Avatar
Default Re: stripping valve cover a bad idea? (Rostr02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rostr02 &raquo;</TD></TR><TR><TD CLASS="quote">I am doing mine and see no problems with it. Strip it with air craft remover then clean it off with laquer thinner before u paint and u should be ok. Just dont get the aircraft remover on you hands unless you want second degree chemical burns. I can vouch for being an idiot. </TD></TR></TABLE>
That stuff does nothing to my hands but when it hits my arm or leg I feel it.
Old Sep 11, 2004 | 12:35 PM
Rostr02's Avatar
Default Re: stripping valve cover a bad idea? (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
That stuff does nothing to my hands but when it hits my arm or leg I feel it.</TD></TR></TABLE>
you have some leather hands then or you dont have it on you hands long enough. I did not notice it burnt my hand until the next day of working with it for like 2-3 hours with no gloves.
Old Sep 11, 2004 | 01:06 PM
B16 CRX's Avatar
My Valve cover it striped down as well, I havent had any problems
HamiltonRex's Avatar
Old Sep 11, 2004 | 01:59 PM
90crxsib16's Avatar
Default Re: stripping valve cover a bad idea? (HamiltonRex)
Old Sep 11, 2004 | 02:39 PM
eda6's Avatar
You'll be fine with a stripped valve cover.
Old Sep 11, 2004 | 02:43 PM
viper_2_4's Avatar
I am pretty sure that the d16y8 valve cover came unpainted.......I can't see it being a problem at all....
Old Sep 11, 2004 | 02:54 PM
kid-honda's Avatar
Default Re: (civiccxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccxr &raquo;</TD></TR><TR><TD CLASS="quote">I am pretty sure that the d16y8 valve cover came unpainted.......I can't see it being a problem at all....
That is true
Old Sep 11, 2004 | 02:55 PM
kid-honda's Avatar
you have some leather hands then or you dont have it on you hands long enough. I did not notice it burnt my hand until the next day of working with it for like 2-3 hours with no gloves.</TD></TR></TABLE>
My hands rock
For some reason I can touch really hot stuff and harsh chemicals?
Maybe its from all the years of skating(falling on hands) wrenching and general labor.
Old Sep 11, 2004 | 04:18 PM
NCRXSi's Avatar
How in the hell is a rock going to make your valve cover crack if a rock should some how make its way to the top of your engine? Is the OEM finish going to prevent that from happening? Can't think of ever hearing of a rock coming through the bumper or even when running without the hood on, coming up and cracking the valve cover.
Old Sep 11, 2004 | 04:31 PM
1.888's Avatar
bead-blasted valve covers are hardcore
much cleaner looking
Old Sep 11, 2004 | 04:58 PM
slowpokesi's Avatar
Default Re: (1.888)
going strong for 2 years, no rocks so far
Old Sep 11, 2004 | 05:21 PM
mEr's Avatar
mEr
Default Re: (slowpokesi)
yeah, youll be fine...ive had mine polished for about 1 year....
Old Sep 13, 2004 | 05:58 PM
Rostr02's Avatar
Default Re: (mEr)
i want to get mine anodized
Old Sep 13, 2004 | 06:16 PM
CRX T-Si's Avatar
Default Re: (Rostr02)
Who ever told you that your valve cover will crack if you strip the paint then you need to run away from this persons opinions.
That is the most silliest thing I had ever heard.
Just go ahead with the paint removal, you will be fine.
OEMFresh1021
Honda Civic (2001 - 2005)
12
Mar 2, 2011 08:11 PM
igone916
Mar 28, 2009 07:54 PM
MrSmith
Oct 26, 2008 08:14 PM
RosSi
Jul 7, 2002 10:35 PM
vtec_powah
Sep 16, 2001 01:19 PM
