Article: "Direct Drive" and Somender Singh - cleaner, quieter, colder burn with 20% less gas?
Old Sep 11, 2004 | 06:16 AM
Black R's Avatar
25 Year Member
Default not quite OT: "Direct Drive" and Somender Singh - cleaner, quieter, colder burn with 20% less gas?
I read an article in Popular Science recently, and some of the theory and practice fascinated me.
I will try to scan and post the article this week, but in the meantime I will summarize:
Somender Singh is a virtual nobody. A guy from Mysore, India who raced motorcycles when he was younger - and like many of us was trying to get that ultimate burn; he "needed his engines to work as efficiently as possible - he wanted the fuel to burn cleanly and under maximum compression. But like most tuners he had run up against compression's upper limit, above which pockets of unburned fuel explode spontaneously, or 'knock' under the pressure...."
Basically there isn't any readily high octane available fuel available to him - so he had to find another way to accomplish his goals. He actually cut little tiny lines or trenches in the cumbustion chamber's "squish band" from the cylinder edge to the spark plug. He found that if he made them deeper, that he could counteract detonation and get a cleaner burn - getting more power, lower temperature's in the exhaust gasses emitted, and less wasted unburned fuel - all while raising the compression of the motor. Side effects of this modification were that the car could idle much lower and the combustion fo the motor's tone was changed - much quieter... He called it "direct drive" because the motor almost didn't need the gearing of a transmission - he could leave it in 4th gear at 500 rpms and just pull smoothly through the powerband, even around town. All this from small displacement motors - motorcycles, two strokes, four strokes, and 50 some odd cars - including 1.2L fiat palio motors, etc...
He kind of reminds me of an Indian Larry Widimere... and now has US Patent # 6237579
An interesting read, and I'd suggest you take a gander at the September issue of Popular Science for more...
It really makes you wonder what he could do with a vtec head.....
The picture of the heads he has modified look very interesting - "Even as a prototype, it's high-concept but exceptionally low-tech, the sort of thing you might be able to make in your own garage with a steady hand and a Dremel tool. Which is, essentially, what Singh did."
Old Sep 11, 2004 | 06:18 AM
Opie's Avatar
Interesting.....
Old Sep 11, 2004 | 06:22 AM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default Re: not quite OT: "Direct Drive" and Somender Singh - cleaner, quieter, colder burn with 20% less ga
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I read an article in Popular Science recently, and some of the theory and practice fascinated me.
Basically there isn't any readily high octane available fuel available to him - so he had to find another way to accomplish his goals. He actually cut little tiny scratches or trenches in the cumbustion chamber's "squish band" from the cylinder edget to the spark plug. He found that if he made them deeper, that he could counteract detonation and get a cleaner burn - getting more power, lower temperature's in the exhaust gasses emitted, and less wasted unburned fuel - all while raising the compression of the motor. Side effects of this modification were that the car could idle much lower and the combustion fo the motor's tone was changed - much quieter... He called it "direct drive" because the motor almost didn't need the gearing of a transmission - he could leave it in 4th gear at 500 rpms and just pull smoothly through the powerband, even around town. All this from small displacement motors - motorcycles, two strokes, four strokes, and 50 some odd cars - including 1.2L fiat palio motors, etc...
It really makes you wonder what he could do with a vtec head..... </TD></TR></TABLE>
Nice Ken! Tech these days and the evolution but something so simple that he did can boost performance like that? You're right, i wonder what he can do with VTEC heads, haha. Its weird though, when you say the " Edge of the Combustion chamber to the spark plug " you mean the dome on the bottom side of the head? So its almost as if you're hiding little pockets of fuel in there? I'd run some insane compression like a diesel engine, LoL.
Kenny - Who's patiently waiting for the Ken Rocker to Scan the article
Old Sep 11, 2004 | 06:30 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">
Its weird though, when you say the " Edge of the Combustion chamber to the spark plug " you mean the dome on the bottom side of the head? So its almost as if you're hiding little pockets of fuel in there? I'd run some insane compression like a diesel engine, LoL.</TD></TR></TABLE>
Yes and no.
"Singh notches his cylinder heads with nicks and scratches to help create turbulence and quickly spread the flame front to the outer reaches of the narrow squish band, creating a more thorough burn."
Modifying the head doesn't change the compression unless you mill it, iirc, so the static compression should remain the same.
Old Sep 11, 2004 | 06:32 AM
Nvious R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">Yes and no.
Modifying the head doesn't change the compression unless you mill it, iirc, so the static compression should remain the same.</TD></TR></TABLE>
Ahhhhhhhhhhhhhhhhhhhhhhhhhh- You could have spent the time you made that last thread on scanning that article or i could just quit my bitching and buy the damn issue, LoL.
OH yeah, with regards to my comment up top, i meant that i would have some insane compression level if knocking wasn't a problem or atleast a smaller problem.
Old Sep 11, 2004 | 07:08 AM
Tweakmeister's Avatar
The pictures are down, but dimples on the piston domes:
http://www.team-integra.net/fo...ion=7
And of course, Endyn with the dimples in the intake ports:
http://www.theoldone.com
And rollerwave pistons:
http://www.theoldone.com/artic...stons/
Old Sep 11, 2004 | 01:02 PM
Nvious R's Avatar
since its so god damn boring here in Washington DC, thanks for supplying reading materials
Old Sep 11, 2004 | 01:08 PM
Black R's Avatar
25 Year Member
.....yeah I know of Larry's head porting with those small dimples near the injectors.
BUT these aren't dimples like a golf ball - these are mini-trenches expanding outward from the valve areas like sun rays..... and they aren't in the intake mainfold or on the tops of the pistons, but near the valves in the combustion chamber side of the head.
I wonder how dimples would affect the swirl in that area compared to these "nicks....."
Old Sep 11, 2004 | 01:15 PM
Stunna BEN's Avatar
Don't call it a comeback
i feel smarter
Old Sep 11, 2004 | 01:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nvious R &raquo;</TD></TR><TR><TD CLASS="quote">since its so god damn boring here in Washington DC, thanks for supplying reading materials </TD></TR></TABLE>
dude I'm directly east of you in Edgewater (south of Annapolis).
yeah, it's boring alright
did go jetskiing Friday afternoon though, it's a fun change...
Old Sep 11, 2004 | 01:36 PM
I wonder how dimples would affect the swirl in that area compared to these "nicks....."</TD></TR></TABLE>
It's not just the dimples though. He also leaves the ported intake side rough (not polished), obviously because if it were smooth the atomized fuel would stick to the walls.
Old Sep 11, 2004 | 03:24 PM
Nishant's Avatar
hmm i have to go buy popular science now
Old Sep 11, 2004 | 08:37 PM
Philly_NBP_R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">hmm i have to go buy popular science now</TD></TR></TABLE>
and scan and post the article for all the lazy fawkers around here...
(like me)
Thanks for posting this Ken.
Old Sep 13, 2004 | 05:45 PM
Black R's Avatar
25 Year Member
Old Sep 13, 2004 | 06:58 PM
that's an awesome read, but it does bring up interesting points:
-Integrity of head
-Compression (lowered?)
Manufacturers are already focusing on flow and "chaotic airflow" ... I give the guy credit, hope it results in something that all the engineers have missed.
Old Sep 13, 2004 | 09:12 PM
georgiajdm's Avatar
yo ken. make the article bigger..I can't see the small letters with my small asian eyes.
Old Dec 16, 2004 | 09:10 AM
johnzm's Avatar
Default Re: (georgiajdm)
ken, excellent find, i only wonder what this does for "hotspots" that we are trying so hard to remove....... i wold think whatever fuel is stuck in those little ridges will detonate rather quickly..
Old Dec 16, 2004 | 09:30 AM
.RJ's Avatar
.RJ
Default Re: (johnzm)
naiyce artic0le, kennay!
Old Dec 16, 2004 | 10:20 AM
dmotoguy's Avatar
Default Re: (.RJ)
it seems like this shouldnt work but i'd love to see it work.. anyone heard anything else since the article came out?
Old Dec 16, 2004 | 11:25 AM
navin's Avatar
Default Re: (dmoto)
I'll have to visit him when I go back to the motherland
Old Dec 16, 2004 | 12:51 PM
RagingAngel's Avatar
Default Re: (navin)
*looks at my dremel.....*
*looks at collection of Dseries motors in backyard*
"I'll be back in a few......."
Old Dec 16, 2004 | 02:16 PM
Aquafina's Avatar
Default Re: (RagingAngel)
We think it will cause detonation from the hotspots, then we read his motto.
-Thinking about spare D heads I have lying around.
Old Dec 16, 2004 | 02:20 PM
E V I A N's Avatar
Default Re: (Aquafina)
Thats so pretty cool stuff.
Karhoot
Jul 1, 2013 07:39 AM
Donkey85
May 9, 2008 08:30 PM
99hondacura
Jul 30, 2006 03:09 AM
BigMoose
Jul 23, 2002 10:52 PM
FlipboiGSR
Sep 4, 2001 08:23 AM
