ANTENNA REMOVAL
Old Sep 11, 2004 | 05:20 AM
RUBZERK's Avatar
Default ANTENNA REMOVAL
I know how to replace the mast on my 5th gen, but i cant get the outer nut off the antenna unit.
Does it turn clockwise or counter clockwise ??
I tried to use a flat screwdriver to loosen the nut but dont budge. Is there a tool i can but to remove it ??
Old Sep 11, 2004 | 05:32 AM
Stew Pidasso's Avatar
Default Re: ANTENNA REMOVAL (RUBZERK)
It is a regualr threaded and yes there is a special tool you can get for it.
Old Sep 11, 2004 | 05:33 AM
RUBZERK's Avatar
Default Re: ANTENNA REMOVAL (Stew Pidasso)
& i can get this tool at ___________?????
Old Sep 11, 2004 | 06:27 AM
Hondaaccordvtec's Avatar
You could take a flat hed screwdriver and place it into the notches that are on top of the nut that needs to come off. Tap the screwdriver with a rubber mallet to get it loose and keep going all the way around it until it comes off.
When you replace the mast and are all set to put the nut back on - coat the threads with either antiseize or vaseline - will keep the threads from rusting up and getting stuck in the future.
HTH
Old Sep 11, 2004 | 07:31 AM
jwogen1's Avatar
dont waste the money on the special tool.....i used needle nosed pliers very carefully in opposite notches of the nut. worked like a charm
Old Sep 11, 2004 | 08:12 AM
SearchBeforeUPost!'s Avatar
Default Re: ANTENNA REMOVAL (jwogen1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 &raquo;</TD></TR><TR><TD CLASS="quote">dont waste the money on the special tool.....i used needle nosed pliers very carefully in opposite notches of the nut. worked like a charm </TD></TR></TABLE>
Old Sep 11, 2004 | 02:39 PM
acurasolution's Avatar
Order your special "antenna socket" at any HONDA or ACURA dealer for around $10.....i bought mine a while back...or you can go to any snap-on truck and ask for one.
Old Sep 11, 2004 | 08:09 PM
RUBZERK's Avatar
does anybody have a oem antenna unit for sale???
i just took mine out of the car & it is rocked & cant be fixed
arielb1
Apr 18, 2016 02:38 PM
stagen
Aug 9, 2007 03:40 AM
MK Ultra
Dec 6, 2006 08:17 AM
Yell00ITR
Apr 11, 2004 09:50 PM
Jordan_4WS
Aug 28, 2002 07:48 AM
