jus finished swap, wont START
Old Sep 10, 2004 | 11:42 PM
rasta420's Avatar
Default jus finished swap, wont START
we just finished swapping a 90 d16a6 into a 88 crx HF. when we turn the ignition on for the first time, the fuel pump comes on strong but there is a spark somewhere under the dash near the fuse box. the engine cranks but nothing.
try to start the car for a second time, and the fuel pump doesnt come on. so i change the main relay to a known working one and it still doesnt come on. then i notice that when the ignition is turned on the check engine light comes on, and stays on. in addition to that, there are no codes on ECU. i check the helms, and it says that it could be a bad ECU, so i change the ECU to a known working one and still same thing.
then i try something else listed in the helms which says to check the no. 14 fuse (10A) in the under dash fuse box which is alternator solenoid i believe, and two other fuses in the engine bay. the no. 14 fuse is blown, and the two in the engine bay are fine. we replace the no. 14 fuse, and turn the ignition on, and it blows again!
im pretty damn lost and confused right now. why would this happen, and would this affect the fuel pump? there is voltage to the fuel pump and the fuel pump is brand new. anyone have any ideas?
thanks
Old Sep 11, 2004 | 12:05 AM
Full Race A6's Avatar
Default Re: jus finished swap, wont START (rasta420)
reset your ecu
Old Sep 11, 2004 | 04:34 AM
crx_88_si's Avatar
Default Re: jus finished swap, wont START (Full Race A6)
you have a short somewhere.. go lookin
Old Sep 11, 2004 | 05:55 AM
HamiltonRex's Avatar
Default Re: jus finished swap, wont START (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">you have a short somewhere.. go lookin </TD></TR></TABLE>
Old Sep 12, 2004 | 09:27 AM
rasta420's Avatar
Default Re: jus finished swap, wont START (HamiltonRex)
****, where to start?
Old Sep 12, 2004 | 09:44 AM
rice_classic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">****, where to start?</TD></TR></TABLE>
Start with checking all the grounds, then end with checking all the powers.
Make sure you don't have 8 guage wire where you're suppose to have 16 and visa versa.
Make sure your grounds aren't too long.
Old Sep 12, 2004 | 10:04 AM
Super Chicken's Avatar
The power feed from that fuse is going somehwere it shouldn't. Start by disconnecting the ECU and then see if the fuse blows. If it still blows disconnect the engine wire harness and than check again. Or disconnect everything first then turn the key on and start plugging **** in till you hear a "pop".
Old Sep 12, 2004 | 11:15 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
http://www.inliners.org/tech/tech6.html
jdmgsr420
Honda CR-V & Element
35
Mar 4, 2012 06:10 AM
si90rex
Jun 24, 2007 05:53 PM
zpat
Mar 22, 2005 11:51 AM
VanishSupra
Sep 4, 2003 11:19 PM
'88civic
Oct 31, 2002 12:56 AM
