B18a Timing Setting
Old Sep 10, 2004 | 09:37 PM
slammedcivicsi's Avatar
Default B18a Timing Setting
My motor seems to have problems running....everyone says timing......when I set the crank pully to the TDC mark and pull the valve cover off the alignment marks on the sides of the cam gears line up....however if you look at the cam mounting holders there are alignment holes on them aswell as matching holes on the cams....the intake cam holder hole aligns with the cam align hole.....however the exhaust cam one seems about 2mm off.....even though the cam gear marks are aligned......do these holes on the cams even have a purpose....Im going to check my Haynes manual tomorrow when I go to my garage, thats where my car is.
Any help is appreciated.
Thanks
-Brad
Old Sep 10, 2004 | 10:40 PM
rev-speed's Avatar
what do u mean by problems running?
does it feel weak
does it bogg
does it missfire
mine have problems running too it just wont hit 10s yet!!!
Old Sep 10, 2004 | 11:02 PM
it boggs down when I press the accelerator......the rpm will pick up if I hold the gas down....but it takes about 4 seconds....and it drops to about 100rpm.
Old Sep 11, 2004 | 05:14 AM
Mike K's Avatar
Default Re: (slammedcivicsi)
there's a chance one of your cams is a tooth off. did u recently do a cam swap or timing belt?
also, burn the haynes manual. helms is the only way to go. and if u think it's too expensive, then i guess proper knowledge and specs aren't part of your plan.
trust me, helms are worth every penny.
Old Sep 11, 2004 | 06:40 AM
rev-speed's Avatar
try swapping the tps and map sensor wire connector sounds like u have then mix
Old Sep 11, 2004 | 07:45 AM
Default Re: (Mike K)
I cant find a helms manual any where in town.....my plan is to buy one off the helms website.
Old Sep 11, 2004 | 07:46 AM
Default Re: (4cylinder)
the wires are correct....because the TPS has 3 wires......now the Civic DX has these 3 wires backwards....so you have to switch them to let the engine know what WOT is.
Old Sep 12, 2004 | 09:41 AM
rev-speed's Avatar
a tps has three wires and so does the map sensor and they will both interchange
lets back up what year car r u runing?
and did u do a dual point to multi port conversiton
Old Sep 12, 2004 | 11:07 AM
its an 89dx.....and yes I did the MPFI conversion......but the TPS has differnt colored wires than the Map Sensor.....so thats how I know its wired correct.
Old Sep 12, 2004 | 03:37 PM
rev-speed's Avatar
i did one of this before
and there was problem with the crank sensor wireing
i follow the instrutions from some website and they were off
disconnet the b10 and b12 wire it 4 crank sensor if it runs fine u need to rewire and check wire
i forgot excatly what i had to do
but it will run without the crank wire
Old Sep 12, 2004 | 04:05 PM
I'll give that a shot.....but I also noticed that after I re-checked the timing today it idles weird.....it idles up and down....within 100rpm.....so This makes me think vacume leaks.
Old Sep 12, 2004 | 09:06 PM
rev-speed's Avatar
no u need to re-adjust idle
the screw on the throttle body
Old Sep 13, 2004 | 08:40 PM
ya...I was planning on re-adjusting the idle when I went to my garage next.....but the fact that it rises and falls made me think something other than just idle problems.
Old Sep 13, 2004 | 08:57 PM
96MidoriHatch's Avatar
haynes
Old Sep 13, 2004 | 09:54 PM
rev-speed's Avatar
there r all kinds of idle problems
so don t jump to conclusions
back up and go back to basics
now that ur sure ur timing belt is timed
make sure ur ignition timing is too.
(igniton timing will affect idle too less timing will drop idle more timing will raise idle)
sayanything
Dec 21, 2010 06:36 PM
DrGrEeNtHuMb
Jul 29, 2009 01:08 PM
93b20z
Oct 11, 2006 07:28 PM
Old_Honda
Jan 10, 2006 09:19 AM
