Want to do a d15b vtec swap....
Old Sep 10, 2004 | 09:25 PM
Schaz's Avatar
Default Want to do a d15b vtec swap....
okay...i have the D15b2 i think it is motor...which really sucks...im leanin towards a d15b vtec....i kno my tranny will hook right up and all that but....what else will i need....them motor does not have a ECU...where would i pick one of these up....also how the hell would i wire this stuff...sorry im only good with body work not motors but thank god for honda-tech!!...also i would like anyone with the d15b vtec in their CRX to post some pics so i can see how it would look thanks
Body is primed paint next week
then teh rims
Old Sep 10, 2004 | 11:47 PM
d16vtecx's Avatar
Default Re: Want to do a d15b vtec swap.... (Schaz)
ok before u do this i want to warn u the total cost comes out to around 1000
u will need ECU, driver side engine mount, wiring harness, distributor, and fuel rail
u will have to rewire the entire dash also to convert it to obd1
i didn't even attempt to do this and i wouldnt advise it unless u hav extensive electrical experience a shop in covina, ca called Honda feind can do this for around 200 bucks
i didn't kno all this till after the d15 vtec was sitting in my engine bay where it has sat for two months i wouyld just go zc dohc bcuz its easier and cheaper bcuz u can get the ECU and wiring harness from an 88-91 civic/crx Si at the junkyard
but if u hav the engine already good luck
Old Sep 11, 2004 | 01:22 AM
plusONE jboy's Avatar
do d15 vtec turbo.
not my car btw: it was member: eg6turbo
Old Sep 11, 2004 | 05:55 AM
crx_88_si's Avatar
Default Re: Want to do a d15b vtec swap.... (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">ok before u do this i want to warn u the total cost comes out to around 1000
but if u hav the engine already good luck</TD></TR></TABLE>
u dont have to re-wire the entire dash, just do a obd0 to obd1 swap and add vtec wiring, done
Old Sep 11, 2004 | 06:26 AM
kid-honda's Avatar
Default Re: Want to do a d15b vtec swap.... (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
u dont have to re-wire the entire dash, just do a obd0 to obd1 swap and add vtec wiring, done </TD></TR></TABLE>
Yea its actually pretty easy.
Old Sep 11, 2004 | 12:41 PM
mr. carpenter's Avatar
Default Re: Want to do a d15b vtec swap.... (kid-honda)
you'll also need a p28 ecu with a vtec activation device or you can get a pm6 modded at zdyne or hondata to activate vtec. it did'nt cost me a 1000$. you can use the si dist.. i've got some pics that show how to use it if needed. as stated it's a pretty easy swap.
Old Sep 11, 2004 | 12:51 PM
onePOINTsix's Avatar
Default Re: Want to do a d15b vtec swap.... (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">you'll also need a p28 ecu with a vtec activation device</TD></TR></TABLE>A P28 ecu has the VTEC curcuity built in, if you get a P06 you'd need to use something to activate vtec. If you doing a OBD1 swap just look for a JDM P08 ecu because thats what came with the D15B in japan
Old Sep 17, 2004 | 03:32 PM
KarbinFourteen's Avatar
Could you send me pics? Karbin_14@yahoo.com
I will be doing the swap soon, just want to throughly understand and get all parts before I get the engine so there are no surprises.
Old Sep 17, 2004 | 04:15 PM
Layziebtnh055's Avatar
Default Re: Want to do a d15b vtec swap.... (KarbinFourteen)
Why would you need adriver side engine mount.....
Old Sep 17, 2004 | 04:42 PM
Sick79's Avatar
Default Re: Want to do a d15b vtec swap.... (Layziebtnh055)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziebtnh055 &raquo;</TD></TR><TR><TD CLASS="quote">Why would you need adriver side engine mount.....</TD></TR></TABLE>
because the drivers side motor mount bracket is differant on an eg. when i did my sohc vtec zc swap i had to swap brackets from an ef motor.
Old Sep 17, 2004 | 04:46 PM
blo2k1's Avatar
Default Re: Want to do a d15b vtec swap.... (Sick79)
[IMG][/IMG] http://www.we-todd-did-racing....D.jpg [IMG][/IMG]
Old Sep 17, 2004 | 04:47 PM
blo2k1's Avatar
Default Re: Want to do a d15b vtec swap.... (blo2k1)
[IMG][/IMG] http://www.we-todd-did-racing....k1NDE [IMG][/IMG]
Old Sep 17, 2004 | 04:49 PM
blo2k1's Avatar
hey hilton aka shaz i told you i would come over and help you out with the swap its easy as hell and so is the mpfi swap use the 5 speed 92-95 p28 ecu best bet and get your self a obd0-ob1 jumper harness and ill show yeah how to do it all
Old Sep 17, 2004 | 05:25 PM
im looking todo this swap too, so where do i get the mount that will fit right....
Old Sep 17, 2004 | 06:24 PM
blo2k1's Avatar
all you have to do is take the actual moutn thats bolted onto the jdm engine by the timing belt off and put the one from your old engine and it wi ll go right in!
Pontas
Sep 7, 2008 12:49 PM
robs93civic
28
Apr 24, 2006 03:46 PM
crxblues
Mar 24, 2006 04:53 PM
em Dot
10
Aug 22, 2004 04:42 PM
