Y1 and J1 transmissions....
Old Sep 10, 2004 | 05:35 PM
marieT1GRL's Avatar
Default Y1 and J1 transmissions....
Yes, I searched and couldn't find what i was looking for. I understand that the Y1 cable trans, has a 4.26 FD and the J1 trans has a 4.40 FD.. (correct me if im wrong ).. Does the Y1 trans have shorter gears than the other? Also, can i put the J1 FD (4.40) into the Y1 trans? The reason why im asking, is because my J1 trans, is messed up, and I have this Y1 as a spare... thanks
Old Sep 10, 2004 | 05:39 PM
SoulSurfer's Avatar
Default Re: Y1 and J1 transmissions.... (ThatOneGirl)
The J1 should have the small shaft so you will need a small shaft tranny to replace any internals. Do you know what year the Y1 is?. I think the 89-90 were small shaft and the 91-92 were big shaft.
Someone correct me if I'm wrong. It's been a while since I've dealt with trannys.
Old Sep 10, 2004 | 05:42 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
The J1 transmission will make the engine rev higher at the same speed than a Y1 transmission would. If what you want is a good drag racing tranny then the J1 would be the one to get. If you want a few less RPM while cruising then the Y1 would be the one to get.
Old Sep 10, 2004 | 06:00 PM
marieT1GRL's Avatar
Default Re: Y1 and J1 transmissions.... (SoulSurfer)
thank you all for the quick responses. Yes, Mr. Spaceballs (blah ) im trying to find a good drag racing transmission, the reason i asked, was because i messed up my J1 trans, and i have a spare Y1 here, now, are the gears and FD interchangeable? Im sorry for all the ?'s... It sucks to be a girl racer who don't know anything about a dam trans... lol.....
Old Sep 10, 2004 | 06:02 PM
marieT1GRL's Avatar
also, will a Y1 trans make me lose mph in the quarter mile? my best ET is 12.2@109mph if that helps..
Old Sep 10, 2004 | 06:03 PM
SoulSurfer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl &raquo;</TD></TR><TR><TD CLASS="quote">i messed up my J1 trans, and i have a spare Y1 here, now, are the gears and FD interchangeable?</TD></TR></TABLE>
It depends on the year of both trannys...
Old Sep 10, 2004 | 06:04 PM
marieT1GRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulSurfer &raquo;</TD></TR><TR><TD CLASS="quote">
It depends on the year of both trannys...</TD></TR></TABLE> Y1 (88-89) and J1 (90-91) i think
Old Sep 10, 2004 | 06:44 PM
marieT1GRL's Avatar
anyone...
Old Sep 10, 2004 | 06:51 PM
fourthgenhatchB17's Avatar
I've *heard* the final drive in the Y1 can not be changed out, unless u change the entire diff. The FD is welded to the diff or sum ****. Y1 and J1 both should have the small shafts, as they both require the use of the 90-91 integra clutch disc, not 92-93 (which is the bigger shaft).
Old Sep 10, 2004 | 07:07 PM
marieT1GRL's Avatar
thanks for the info (fourthgenhatchB17).. btw, in your sign, i would pick the straight rotas. lol
Old Sep 10, 2004 | 08:50 PM
rioninja's Avatar
Thats correct, you can interchange gears between these trans.
But IMO, i would definatly use the y1 as is, untouched. First gear in the j1 is so 'low' its rediculous. Its practically useless if your making any power at all. The y1 actually has a minutely closer gear ratio than the j1, but 1st gear starts 'higher' because of the final drive. Y1 without a doubt IMO
Old Sep 10, 2004 | 09:02 PM
VtecKiDD's Avatar
Default Re: Y1 and J1 transmissions.... (rioninja)
for what its worth, i put a Y1 LSD into a S1 Tranny with ZERO problems.
Old Sep 10, 2004 | 09:35 PM
EJ2-Fluffy's Avatar
Default Re: Y1 and J1 transmissions.... (VtecKiDD)
Yeah but the S1 is out of the question. All she has in the broken J1 transmission and Y1 Transmission. I think I would go with the J1 transmission (Shorter gearings) for racing since that's what your using it for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">for what its worth, i put a Y1 LSD into a S1 Tranny with ZERO problems.</TD></TR></TABLE>
G'luck.
-Jon
Old Sep 10, 2004 | 09:39 PM
VtecKiDD's Avatar
Default Re: Y1 and J1 transmissions.... (CRX-Fluffy)
yeah id sitck with a J1 over a Y1. But dont ALL the Y1s have LSD? I have seen about 10 that do have LSD so im making an assumption. I was told that the diffs wouldnt match in my swap, but the trans runs fine, and ive had no issues out of it for 4000k miles.
Old Sep 10, 2004 | 09:44 PM
marieT1GRL's Avatar
Thanks for all your help everyone. My Y1 doesn't have a LSD in it any more suggestions? Tbone, get your *** in here...... now.. j/k
Old Sep 10, 2004 | 10:22 PM
b16_madman's Avatar
I haven't ridden in other b series ef's but gaw the j1 first gear is pretty useless.
What's gone bad on the J1?
It might be repairable.
Old Sep 10, 2004 | 10:36 PM
marieT1GRL's Avatar
Default Re: Y1 and J1 transmissions.... (B16_madman)
the casing, and shift forks things? Im tranny stupid
Old Sep 10, 2004 | 11:09 PM
b16_madman's Avatar
so casing is cracked i assume? and the forks that slide the gears into place etc?
I was gonna suggest a hybrid tranny in a different casing, but I don't know if the two are the same size or not. Interesting, how'd it happen, may I ask?
Old Sep 11, 2004 | 12:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info (fourthgenhatchB17).. btw, in your sign, i would pick the straight rotas. lol </TD></TR></TABLE>
Same choice here...ahah. To answer someone elses question, not ALL Y1's come with LSD.
Old Sep 11, 2004 | 04:33 AM
crx_88_si's Avatar
Y1 = JDM CRX Sir 89-91
J1 = JDM Teg XSi/RSi 90-93
search google for gearspeed and call them. Saw a big write up in Honda tuning on this exact topic. apparently the guys at gearspeed are the pro's.
Old Sep 11, 2004 | 02:13 PM
DEVIOUS_EG*'s Avatar
Can't you use the FD from the J1 and put it in the Y1?... Would that make a difference also... and make the Y1 gears act like a J1? There both the small shafts anyways.. right guys? im lost
trianglegreg
17
Mar 12, 2008 12:08 PM
hYpE-R-29
Acura TL, RL & ZDX
Nov 30, 2006 05:27 AM
K-Drum
Jul 19, 2004 10:16 AM
