Whats the difference between the full swap and the engine, ecu and tranny?
On hmotorsonline I noticed its considerably cheaper for the Ecu, engine and tranny than for the full swap. Is there anything critical you're missing out on without the full swap?
okay so you are on the page and don't read it?
http://www.hmotorsonline.com/s...30016
Full swap = READ
http://www.hmotorsonline.com/s...30015
engine tranny ecu = READ
Full swap = READ
Sheesh sorry I did. I was wondering whether I will need the:
- Axles with Half Shaft
- Shifter Cables
- Shifter Assembly
- Stock Motor Mounts
or if my existing parts will work. Thats all.
- Shifter Cables
- Shifter Assembly
heh ok i understand. Im swapping this in for my F22 so the axles and everything should work right?
Go to http://www.slhondaparts.com/br...ELUDE and check the model numbers of your parts comparing them with those off of the VTEC. If they are the same, you are good. If they aren't, you will most likely need to change them.
If you find something that's different, ask and I'm sure somebody will know for sure...
full swaps are for when you're swapping into civics etc when you need the shifter linkage etc. you don't need it if you have a prelude.
Xanthias
Jan 11, 2013 12:34 PM
jadugartir
Dec 31, 2004 10:17 AM
