caliper brakcket super hard to take off..
on a bb1 lude.. im trying to put on some new rotors and i cant get either of the bolts for the caliper braket to budge. tried wd40, using ahammer to hit the rachet, and a breaker bar too, but there isnt too much space to turn either with the breaker bar either.
wish i had alift
wish i had alift
I suggest some pb blaster to start off. Spray it and let it soak in for a couple days. Continue to spray every day for those days also. And for a lift try to get a hook up from a friend or family u could use for a couple hours. There has to be someone and basically u need some air tools it is a pain in the *** otherwise
u can take it apart two ways
1 remove the whole caliper with braket
take off the two 17 mm bolts
2 remove it by the caliper the two 10mm bolt
if both r stuck and u don t have air tools
put everything back go to a shop and pay them $10 to loosen the bolts
beats stressing out!
the next problem u ill have is takeing out the screws on the caliper u may need a impact driver
Traction
Jul 30, 2004 07:01 PM
95TEG
15
Oct 6, 2003 07:22 AM
