vtec oil pressure switch torque specs
Old Sep 10, 2004 | 02:10 PM
wannagofaster's Avatar
Default vtec oil pressure switch torque specs
what is the vtec oil pressure switch torque spec for 99 gsr.
thanks
Old Sep 10, 2004 | 02:15 PM
evil_schmevil
Guest
Posts: n/a
Default Re: vtec oil pressure switch torque specs (wannagofaster)
aren't those about 5mm bolts (maybe 6)? just tighten them the same as any other 5mm bolt.
Old Sep 10, 2004 | 02:27 PM
Default Re: vtec oil pressure switch torque specs (evil_schmevil)
no, these are like 17 mm bolts
Old Sep 10, 2004 | 02:37 PM
evil_schmevil
Guest
Posts: n/a
that's the length. I'm talking about diameter. For any given non-critical bolt like the VTEC switch bolt the torque spec is going to be about the same for any bolt regardless of length as long as the diameter is the same.
Now for head bolts, crank main cap bolts, rod bolts, wheel bolts, things that are highly loaded and critical for safety, this does not hold true. But for a non-critical engine part it will be.
just don't overotrque, if I recall correctly those bolts go into the threaded aluminum head. Not good to strip the head.
the.hamburglar
Feb 17, 2006 06:48 AM
92eg6lsvtec
11
Jul 9, 2005 12:57 AM
92-LS-Civic
Oct 7, 2004 07:47 AM
sneakychaos
Sep 21, 2004 03:30 PM
