integra auto to manual swap
Old Sep 10, 2004 | 10:14 AM
seros's Avatar
Default integra auto to manual swap
ok guys i am in need of any 411 ...links.... or anything usefull u can trow my way bout how to do a auto to manual convertion in an integra
iv found planty threads on how to swap an eg from auto to 5speed but nothing bout integras
i found this write up bout egs
http://www.homemadeturbo.com/f...26615
but id looooooove to find an well writen write up on integras
plzzzzz help
Old Sep 10, 2004 | 10:24 AM
virusiidx's Avatar
https://honda-tech.com/zerothread?id=273253
This thread helped me a lot on my auto to manual swap.
Old Sep 10, 2004 | 01:35 PM
seros's Avatar
Default Re: (virusiidx)
thanks any1 else?
Old Sep 10, 2004 | 01:50 PM
njandrewg's Avatar
Default Re: (000s)
step 1-sell ur current teg
step 2-buy a new teg in manual
step 3-profit by a 200-400 bucks since autos are easier to sell and are considered more expsneive
auto to manual converision complete. not really worth it to do the swap with a teg when u have a buttload of same cars available in stick
Old Sep 10, 2004 | 02:33 PM
virusiidx's Avatar
Default Re: (njandrewg)
yeah the cheapest way would be to sell it. But if you really put a lot already into your car (like me) then go for the auto to manual swap and you'll appreciate it a lot more.
Old Sep 10, 2004 | 04:23 PM
driftmaster004's Avatar
Default Re: integra auto to manual swap (000s)
ive been thinkin about doin this also but is it fairly reliable afterward or have u guys had problems with it later on?
Old Sep 10, 2004 | 08:04 PM
l4 soldier's Avatar
Default Re: integra auto to manual swap (driftmaster004)
autos are actually cheaper in souther cali. cuz the import scene is so big here no one wants an auto
Old Sep 10, 2004 | 08:32 PM
xiLLtegRax's Avatar
Default Re: integra auto to manual swap (l4 soldier)
my cousin got it done. it seems fine to me
Old Sep 10, 2004 | 08:37 PM
integraL's Avatar
Default Re: integra auto to manual swap (xiLLtegRax)
i dont believe in the time/money/hassle/headaches. just buy a manual car!
Old Sep 10, 2004 | 08:43 PM
seros's Avatar
uhhh no
im sorry yall overpaid for ur car
and i wasnt asking whats the cheppest way to get a 5speed
i bought a shell for dirt cheep no motor no nothing so im getn a new motor anyways and everything re-done ... the pedal assembly is preety much accounted for
my main question is bout wireing!<U></U>
the reverse light?? how do i wire that up?
and how do i wire the thing to be in park mode or whatever that i have to do to get the key out?
any other wireing that i should know bout that im gonna need to do?
HELPP
Old Sep 10, 2004 | 09:56 PM
Kendall's Avatar
You'll need to source all the necessary parts, such as the correct pedal set, clutch master cylinder, hard lines, slave cylinder, the tranny, clutch, flywheel, correct ECU, shift linkage, shifter, shift ****, bushings, fasteners, and anything else I may have missed. The biggest issue you'll run into is the location of the upper tranny mounting location. You'll either have to fabricate a new mounting location (I've done it before and it's not that hard), or buy the necessary conversion mount from somewhere such as Place Racing.
Old Sep 10, 2004 | 09:58 PM
Kendall's Avatar
Regarding the wiring, the reverse light sensor thingy just plugs right in and you shouldn't have any issues, the only other wiring we had to do was run a jumper wire to bypass the neutral safety switch (really really easy).
Old Sep 11, 2004 | 09:25 AM
seros's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote"> the reverse light sensor thingy just plugs right in and you shouldn't have any issues,
the only other wiring we had to do was run a jumper wire to bypass the neutral safety switch (really really easy).</TD></TR></TABLE>
thanks but im kinda lost with prolly the dumbest look in my face right now the reverse sensor thingy plugs where??
the wireing harness by the center console had sum plugs that were supposta plug into the auto shifter... is that what ur talking bout? should i leave does pluged in?
(i read to bypasss the park setting to take the key off i should leave that white box pluged up)
and wheres the neutral safety switch and whats the point of that?
thanks againg
limit
Jan 26, 2009 12:27 PM
Happyme
Nov 26, 2007 07:35 PM
ahmad-a
Dec 2, 2006 09:16 AM
spoonlongblock
Nov 5, 2003 06:31 PM
