Skunk 2 cams in an H22 (USDM)- should we go Stg 1 or Stg2?
Old Sep 10, 2004 | 10:11 AM
Mr Black's Avatar
Default Skunk 2 cams in an H22 (USDM)- should we go Stg 1 or Stg2?
OK, the motor has the stock 10:1 comp, I/H/E and AEM adjustable FPR, no Hondata or VAFC.
Given the above parameters, which cam is a better choice for aggressive street performance and why? The rumour mill says Stg2's on 10:1 compression will not realize the full potential of these cams and the results can be disappointing. Anybody think differently? Anybody put in the Stg1's and see a noticeable difference over stock?
I have seen ONE dyno graph comparing the 2 grinds, along with Type-S cams, but I think that was on at least 11:1 compression.
Old Sep 10, 2004 | 10:50 AM
SuperSlow's Avatar
Default Re: Skunk 2 cams in an H22 (USDM)- should we go Stg 1 or Stg2? (Mr Black)
Stick with Stage 1 unless you are planning on building later.
All the bigger cams really shine under higher CR.
Old Sep 10, 2004 | 11:49 AM
Mr Black's Avatar
Default Re: Skunk 2 cams in an H22 (SuperSlow)
Cool, anyone else? I found loads of feedback on the Stg 1's in B motors, but none for H22's.
g23cg5
Nov 15, 2013 04:58 AM
1fastlude1
Jan 19, 2011 07:33 AM
DOHCMonster410
Sep 29, 2009 01:32 PM
jdm.ejone
Oct 10, 2007 10:44 AM
95accordh22a
Feb 10, 2005 03:28 AM
