RPM and engine goes up and down
Old Sep 10, 2004 | 09:21 AM
carloss's Avatar
Default RPM and engine goes up and down
1989 CRX. 1.5 L engine, manual trans. It has a throtle body, not fuel injection.
While idling in neutral, the rpm and the engine revs up to about 1700 to 2700 and then back down to 1700. It just keeps going up and down. The problem is very erratic.
Where is the fuel filter? What is a magnetic valve?
Please help.
Old Sep 10, 2004 | 09:24 AM
bambam's Avatar
Default Re: RPM and engine goes up and down (carloss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carloss &raquo;</TD></TR><TR><TD CLASS="quote">1989 CRX. 1.5 L engine, manual trans. It has a throtle body, not fuel injection.
Please help.</TD></TR></TABLE>
It has a throttle body but not fuel injection?
&lt;----scratches head...
Old Sep 10, 2004 | 10:02 AM
crx_88_si's Avatar
vacuum leak.
Old Sep 10, 2004 | 10:31 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (crx_88_si)
Its DPFI...
IAC Valve?
Old Sep 10, 2004 | 10:33 AM
fastasssi's Avatar
spray carb cleaner all around the intake and carb on all the gaskets and see if the idol changes if you hit a vacuum leak the rpm's will go up then you found your leak most likely at the head from the manifold
Old Sep 10, 2004 | 10:59 AM
bambam's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Its DPFI...
IAC Valve?</TD></TR></TABLE>
Yah i know...just thought it was funny...throttle body...but not fuel injected...lol.
Old Sep 10, 2004 | 11:07 AM
carloss's Avatar
Default Re: RPM and engine goes up and down (bambam)
sorry about my ignorance, It is not fuel injected for sure. It has a carburator.
Old Sep 10, 2004 | 11:10 AM
carloss's Avatar
what is DPFI and IAC.
Intake Air Control Valve?
Why does it only happens sometimes, if it is a vacuum leak?
Old Sep 10, 2004 | 11:11 AM
bambam's Avatar
it isn't carburated. It is definitely fuel injected with a throttle body. unless you got one of those rare crx's.....lol. it's dpfi...which means there are only two injectors with a top mounted throttle body...that black almost square box is just a hollow box with a mesh filter to redirect the air and make sure no large debris such as mice don't get in.
i know this is kind of off topic but just incase...because i don't want him going to autozone for a part and they ask him which car he has and he says carburated...lol.
Old Sep 10, 2004 | 11:12 AM
bambam's Avatar
dpfi= dual point fuel injection.....2 injectors in the Throttle body instead of mpfi which has 4 injectors located in the plenums of the intake manifold
ActiveAero
Feb 15, 2026 03:06 PM
paranemertes
May 11, 2015 09:46 PM
spyda man
Aug 21, 2007 09:31 AM
