timing belt change?
Old Sep 9, 2004 | 08:12 PM
cbmprelude's Avatar
* B A N N E D *
Default timing belt change?
I have a fifth gen prelude and I want to change the belt myself. Can I just slip the old one off anf the new one on as long as i dont move the camshafts or crank. Also when is the recomenede change of the timing belt.
Old Sep 9, 2004 | 08:57 PM
Hawkze_2.3's Avatar
Default Re: timing belt change? (cbmprelude)
I wouldn't try without at least some experience and a Helms...
In theory it seems like you could just slip it on and off, but it never just works like that. I always have to manually turn the cam gears to get the belt on right, and if you **** it up, you just bought a new or rebuilt head.
Old Sep 9, 2004 | 09:01 PM
john d
Guest
Posts: n/a
Default Re: timing belt change? (Hawkze_2.3)
i wouldnt suggest just slipping it off... you will need a special tool called a stopper for your auto tensioner, its like $15 from honda, i can sell it to you if u want. i just did mine like 2 weeks ago. also, i suggest using a helms while doing this
Old Sep 9, 2004 | 09:17 PM
SKDRCR's Avatar
Default Re: timing belt change? (john d)
i can imagine how much of a pain in the *** it would be
with the auto-tesioner. you should just upgrade to the manual
tensioner. it's not that hard, just get the parts and follow the
instructions and you'll be good.
Old Sep 10, 2004 | 07:07 AM
yellow_jacket's Avatar
Default Re: timing belt change? (SKDRCR)
You will definetely need to get the auto tensioner tool. The reason you can't slip it off is because there is always tension on the belt somewhere. In order to get the belt on you need to just barely move the cam gears to get slack, then move them back once the belt is on.
Old Sep 10, 2004 | 08:55 AM
red92si's Avatar
I wouldnt suggest doing the timing belt change yourself unless you are mechanically compitent and have a Helms manual right in front of you. I would also suggest you change to the H23 manual tensioner when you get the belt changed, the autotensioner is known to fail unexpectedly (especially if power has been increased)
Old Sep 10, 2004 | 10:49 AM
LudeyKrus's Avatar
As said before, don't do it unless you have the manual and someone w/ you that knows their way around a motor.
It is easy to get those teeth off, and to tension it wrong if you don't know how.
Also, it's fairly involved for someone who's never done anything big. BUT if you're very familiar w/ your car, and have the time and tools, it's a good time to learn and save some cash.
Old Sep 10, 2004 | 11:19 AM
collije's Avatar
Agreed to what's been stated above. Helms & being mechanically-inclined are what's needed. Switchout to manual tensioner is recommended as well.
Old Sep 10, 2004 | 11:26 AM
biglew's Avatar
Default Re: (collije)
Why does every sone always say Helms (plural). If you think it's just a slip of and slip on ordeal you are in for a HUGE suprise.
Old Sep 10, 2004 | 11:58 AM
Hawkze_2.3's Avatar
Default Re: (biglew)
Helms possesive, not plural.
Old Sep 10, 2004 | 12:59 PM
biglew's Avatar
Default Re: (Hawkze_2.3)
Oh so you start your car with a Hondas key and watch DVDs on a Sonys stereo.
Old Sep 10, 2004 | 01:11 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglew &raquo;</TD></TR><TR><TD CLASS="quote">Oh so you start your car with a Hondas key and watch DVDs on a Sonys stereo. </TD></TR></TABLE>
And what if I do?!
Old Sep 10, 2004 | 07:37 PM
biglew's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">And what if I do?!
</TD></TR></TABLE>It's great
Old Sep 15, 2004 | 06:19 AM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Helms possesive, not plural.</TD></TR></TABLE>
possesive would actually read "helm's"
Old Sep 15, 2004 | 09:25 AM
matix's Avatar
Default Re: (AK1200)
I am planning on doing the auto to manual tensioner swap when i do my timing belt. I was wondering i am gonna do away with my balancer shaft belt. So do i need the H23 balancer shaft tensioner pulley. Bc on the parts list its like 40-50 dollars. I would like to save that money.
Old Sep 15, 2004 | 09:31 AM
SKDRCR's Avatar
Default Re: (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on doing the auto to manual tensioner swap when i do my timing belt. I was wondering i am gonna do away with my balancer shaft belt. So do i need the H23 balancer shaft tensioner pulley. Bc on the parts list its like 40-50 dollars. I would like to save that money.</TD></TR></TABLE>
You don't need it but it makes it easier.
If you're using the h22 bs pulley, j00 will need the 3mm washer between
the two pulleys so they clear eachother.
f20beme
Apr 8, 2015 07:47 PM
ragnarok0mega
Sep 16, 2009 08:35 PM
chibiko
Feb 22, 2007 05:45 AM
maiv01
Dec 9, 2005 02:02 PM
gofastgsr
Dec 6, 2003 11:18 PM
