b20 vtec N/A
Old Sep 9, 2004 | 07:26 PM
ceLtic's Avatar
N/A wh0re!
Default b20 vtec N/A
b20Z block
b18c/b16 head....
what can i rev this out to max with a dohc vtec oil pump and doing it properly with dowl pins.......any info? i want torque...and might also be considering an ls/vtec....
any info on which would be best for N/A?
Old Sep 9, 2004 | 08:11 PM
Dancing is Forbidden's Avatar
Default Re: b20 vtec N/A (ceLtic)
Ive seen them rev to 9500 with the proper valvetrain.
Id rev that setup to 8200 easily.
Old Sep 9, 2004 | 08:15 PM
DEVIOUS_EG*'s Avatar
stock b20z?.. i wouldn't rev that **** pass 8200...
Old Sep 9, 2004 | 08:20 PM
ceLtic's Avatar
N/A wh0re!
Default Re: b20 vtec N/A (DEVIOUS_EF*)
so with retainers....springs....cams....and the vtec head...i can easily take it to 9k?
i heard the "sleeves" are week....but that is for fi...what about n/a?
Old Sep 9, 2004 | 08:24 PM
yes.. but on a stock block.. i wouldn't... but, i've seen people take that **** all the way to 8700+ rpm.... motor didn't last as long.. good luck on your build..
Old Sep 9, 2004 | 08:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote"> i heard the "sleeves" are week....but that is for fi...what about n/a? </TD></TR></TABLE> on your "stock" block build up.. your fine.. dont rev to high.. but if you plan on building a daily driver, don't go over 11.5:1 84.5mm... most important.. tune it...
Old Sep 9, 2004 | 08:50 PM
ceLtic's Avatar
N/A wh0re!
i want a daily driver...occasionally going to the track/street races...
i want to know if i fully build the head...springs retainers....and a set of cams....and basically keep the bottom end stock...what would i be able to spin it to before it goes kaput!
Old Sep 9, 2004 | 09:28 PM
MonkeyManStunna's Avatar
i've had ppl say that they would never rev past 6 cuz thats what the b20 revs up to...and then ofcourse i hear other saying that they rev to 9 and have no problems... personally i wouldn't rev past 8200 cuz i think that you should at least sleeve the block before you raise that rev limiter.
Old Sep 10, 2004 | 10:29 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">so with retainers....springs....cams....and the vtec head...i can easily take it to 9k?
This is true, the sleeves are weak, so I would sleeve it! Make sure to get ARP Rod bolts and possibly new rods! You have to remember those rods weren't meant to rev that high and they will stretch! You wouldn't rev a stock B16 rods to 9500rpms would you! I hope not, it would work for a while until one day it'll break!
Old Sep 13, 2004 | 10:29 AM
ceLtic's Avatar
N/A wh0re!
Default Re: b20 vtec N/A (hybrid_vtec)
what if the head is built? springs retainers/cams...what would you rev it to on a stock block?
Old Sep 13, 2004 | 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">what if the head is built? springs retainers/cams...what would you rev it to on a stock block? </TD></TR></TABLE>
Head has nothing to do with the block! I suggest new bearings and ARP rod bolts and you can rev to 8K no problem on stock bottom, but be careful! Dont mis-shift!
Old Sep 13, 2004 | 11:20 AM
Oh and for a B20 block I would reenforce the walls somehow! Either sleeves, block guard, or stud kit from endyne!
Old Sep 13, 2004 | 05:41 PM
bboyoxygen's Avatar
I have a B20B stock block with JE 10.5:1 Pistons.. B18C1 stock head and I redline around 8200... My peak HP is around 7900 so I rarely shift above that. The motor runs great and I am pretty even with stock type-r's. I'm going to be doing my exhaust and getting cams soon so that should give me a little more! I/H/E Si's and GSRs cant touch me!
In all reality you shouldn't worry about how high your redline is. Just know where your peak horsepower will be and figure out the best shift points. My vtec engages at 5600RPMs and pulls hard to redline but I still shift at 7900 because I found that to be my best shift point.
The best thing I can tell you about this motor is that when I'm in 5th gear on the freeway and I start going up a hill I do not have to down shift.. Just push the pedal down a little more and my car speeds up quickly.. This car is a blast to drive down mountain roads and around curves.
Old Sep 14, 2004 | 06:35 AM
Default Re: b20 vtec N/A (bboyoxygen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboyoxygen &raquo;</TD></TR><TR><TD CLASS="quote">I have a B20B stock block with JE 10.5:1 Pistons.. B18C1 stock head and I redline around 8200... My peak HP is around 7900 so I rarely shift above that. The motor runs great and I am pretty even with stock type-r's. I'm going to be doing my exhaust and getting cams soon so that should give me a little more! I/H/E Si's and GSRs cant touch me!
The best thing I can tell you about this motor is that when I'm in 5th gear on the freeway and I start going up a hill I do not have to down shift.. Just push the pedal down a little more and my car speeds up quickly.. This car is a blast to drive down mountain roads and around curves. </TD></TR></TABLE>
What is done to your block? Also 7900 isnt really bad, but it still isnt that good since LS rods began to stretch at 7800! So like I said 7900 isnt that bad, just make sure you have ARP rod bolts!
Old Sep 14, 2004 | 10:20 AM
jwaked's Avatar
Like bboyoxygen said, no point on going over 8200 RPMs with your setup. Going over that won´t make you any faster but will help you destroy your engine sooner.
Jay
Old Sep 14, 2004 | 12:45 PM
bpowa's Avatar
Default Re: b20 vtec N/A (jwaked)
i take mines to 7500 on a stock block and itr head.. just to be safe.. have not dyno yet to know if i make power to 8000 but most of the graph i have seen on a stock b20vtec the power drops off at 7200-7500.
Old Sep 14, 2004 | 02:22 PM
COUPE-B20's Avatar
I think it would do good to build the block...........
Old Sep 14, 2004 | 04:23 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">stock b20z?.. i wouldn't rev that **** pass 8200... </TD></TR></TABLE>
7800 if it is stock block
8500 with arp rod bolts....
importlegions
26
Oct 27, 2016 08:12 AM
OttomansAlive
Jan 20, 2010 07:38 AM
98y8
10
Jan 16, 2010 09:26 AM
slowwwtegra
Aug 15, 2007 09:00 PM
sileighty_911
Jul 24, 2007 01:15 PM
