How to set distributor to sixteen degrees?
You'll need a timing light. Simply aim the light at the crank pulley and adjust the distributor until the correct timing mark lines up with the indicator. The mark you use will depend upon whether you're using a standard timing light or an adjustable one.
FlewByU352
Nov 13, 2010 07:27 PM
jdmjopey
Mar 24, 2004 08:47 PM
