b16 axle problem
I need help! I've installed a 91 integ. LS axles on my 91 crx w/ b16 swap and now the whole driverside shakes up and down. I can't go pass 10mph without the car feeling like the front end is going to break. The axles are reman. Is there something wrong with my inter. shaft or hub?
You have to remove the dust shields on teh inside of the hub on your car, and a black rubber "seal" on the outer cv of axle on each side IF it comes with one. Sometimes they do, sometimes they dont.
I think there're teg int. shaft cause there was no problems before. I just got another axle so hopefully it fixes the problem. I think the axle may have been bent. But, when the problem occurs the engine also moves back and forth. Thanks for all the help.
I put the new 91 teg. axle on and it still did the same thing. I notice the top rear tranny mount bolt is missing. The one that bolts up to the engine. Would that cause the engine to shake when the axle is on? I also removed the rubber on the cv and the hub shield. Can somebody please help!
user 72830283
12
Sep 26, 2005 05:01 AM
crexer
27
Dec 22, 2004 10:39 PM
Karterguy13
Apr 12, 2004 02:23 PM
red civic standard
23
Nov 30, 2002 07:30 PM
