starting up problem
Old Sep 9, 2004 | 06:28 PM
stivic's Avatar
Default starting up problem
just pulled my D16 and put in the GSR set up everythings connected but no spark to my plugs i cant get it to start, water did get in the plug holes but not below the plugs before i took them out i air brushed all the water away but do you think the water had anything to do with it
Old Sep 9, 2004 | 10:28 PM
rev-speed's Avatar
check the coil
take the cap out and stick a plug wire on the coil
then put a spark plug wire on the other end and grond it or lay it on the valve cover
now turn the key on and with a wire tap the coil negative side to ground u should have spark.
jakescakesz06
Jan 4, 2016 09:38 AM
ProjectEvilEj2
Jan 1, 2009 08:10 AM
slowd16z6
Mar 13, 2004 07:12 PM
crxY-49
Sep 10, 2003 12:23 PM
mickey513
Jan 29, 2003 06:43 PM
