F22b w/ H23a block I heard it pumps out 230hp @wheel
Old Sep 9, 2004 | 06:25 PM
EMCEEREYREY2002's Avatar
Default F22b w/ H23a block I heard it pumps out 230hp @wheel
I have been looking for a good combination and i heard that an f22b head with a h23a block gives 230hp at the wheel is it true
Old Sep 9, 2004 | 06:27 PM
FatJoe's Avatar
Default Re: F22b w/ H23a block I heard it pumps out 230hp @wheel (EMCEEREYREY2002)
maybe if you put some stage 3 cams in there, an SMSP header, 2.5 inch exhaust, test pipe, adjustable cam gears dyno tuned, hondata (or whatever standalone system you would want) p&p'd head, blah blah blah.
Old Sep 9, 2004 | 11:05 PM
Eddiebx's Avatar
yeah it will make 230whp, mebbe wit a turbo on it,
and just so that you know, an f22b head is pretty much the same as the h23 head, so this "frankenstien" motor you created is pretty much a stock h23, hehe
Old Sep 10, 2004 | 07:05 AM
Fook_me_honda's Avatar
Default Re: (Eddiebx)
Isn't the H23 the prelude doch non-vtec, will it actually fit on a sohc f22
Old Sep 10, 2004 | 07:09 AM
TxTuner
Guest
Posts: n/a
Default Re: (Fook_me_honda)
This swap was just made recently by another HT member. He should have a full write up on it shortly.
Old Sep 10, 2004 | 07:11 AM
Lostcb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fook_me_honda &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the H23 the prelude doch non-vtec, will it actually fit on a sohc f22</TD></TR></TABLE>
It is indeed from the prelude, but beware Honda also produced a h23 dohc vtec engine (blue valve cover) that was in the SiR accord wagon.
Old Sep 10, 2004 | 07:25 AM
TxTuner
Guest
Posts: n/a
Default Re: (Lostcb7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lostcb7 &raquo;</TD></TR><TR><TD CLASS="quote">It is indeed from the prelude, but beware Honda also produced a h23 dohc vtec engine (blue valve cover) that was in the SiR accord wagon. </TD></TR></TABLE>
Yeah, those bitches are mad JDM y0!!!
Old Sep 10, 2004 | 07:27 AM
urbanlegend21's Avatar
New User
will not make that without SERIOUS work..........
H23 bottom end, F22 crank, H22 head with Jun 3 cams, P&P, Accord Type R intake mani, nasty big injectors, SMSP prototype header, etc will make that though
Old Sep 10, 2004 | 07:30 AM
TxTuner
Guest
Posts: n/a
Default Re: (urbanlegend21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">This swap was just made recently by another HT member. He should have a full write up on it shortly. </TD></TR></TABLE>
urbanlegend21 is right, but to quote myself, we'll find out soon enough.
Old Sep 10, 2004 | 08:14 AM
BoostedH23Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fook_me_honda &raquo;</TD></TR><TR><TD CLASS="quote"> will it actually fit on a sohc f22</TD></TR></TABLE>
Yes it will... i'll have a write up including pics later today
Old Sep 10, 2004 | 09:32 AM
Default Re: (BoostedH22Accord)
BTW you will not put out 230Hp by just the head swap.
Old Sep 10, 2004 | 12:35 PM
TxTuner
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH22Accord &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will... i'll have a write up including pics later today</TD></TR></TABLE>
See, See, here he is! And you all doubted me
Old Sep 10, 2004 | 03:42 PM
Schmitey's Avatar
Default Re: (TxTuner)
yeah there's already a write up on a guy that did the F22 block and h22 head (vtec but same head size/shape). He used it for a turbo setup cuz the blocks are dirt cheap and he wouldn't care if he blew it. Last I checked he didn't have a dyno yet but he had some serious problems with it.
He was doing all sorts of crazy ****. Blocking oil drain holes on the block, fabricating his own coolant hoses cuz the head stuck out further, counting teeth on the sprockets, vtec not kicking in, check engine lights, etc.
Not to discourage you where there's a will there's a way, but I hope you got a second car in the meantime.
Old Sep 13, 2004 | 09:26 AM
Default Re: (Schmitey)
Mechanically it can be done. With the H23 head all you have to do is switch the lower timing gear as for oil drains if you use the F23 headgasket you will be fine. With the H22 head you will have to plug a couple of drains, that will not affect engine performance. If you choose to use an H22 head you will need to install a knock sensor since the F22 doesn't have one. As for the H23 head on the F22 you don't need to plug anything. I did on mine only because the original test fitment was done with an F22 headgasket. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote"> Last I checked he didn't have a dyno yet but he had some serious problems with it.
Not to discourage you where there's a will there's a way, but I hope you got a second car in the meantime.</TD></TR></TABLE> As for Prelittlelude's set up his issues will be solved once he is using his AEM ems to bypass the knock sensor. Thats why Vtec will not work once he throws a CEL. As far as counting teeth on the spocket thatwas to find out which one will work.
The bottom line is that it runs.
Good luck
Old Oct 25, 2004 | 04:43 PM
fastludeh22's Avatar
Default Re: (BoostedH23Accord)
all this sohc f22 h23/22 stuff is true and great, but.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yeah it will make 230whp, mebbe wit a turbo on it,
and just so that you know, an f22b head is pretty much the same as the h23 head, so this "frankenstien" motor you created is pretty much a stock h23, hehe</TD></TR></TABLE>
he is right, orignal poster was talking about f22b
Old Oct 25, 2004 | 07:10 PM
pyrojeff's Avatar
Default Re: (fastludeh22)
I heard you can put a b18c5 head on an h22 block and get 320 whp, but I'm just pulling that out of my ***.
NAh22a444
Nov 3, 2009 12:58 PM
boostedh22lude1
Oct 5, 2007 09:09 AM
gosu08
Aug 25, 2006 10:08 PM
n8dogg
Apr 12, 2005 01:31 PM
