Running B20vtec w/ GSR ecu?
Planning to use ITR cams, looks like the appropriate vtec engagment should happen at about 4.5k rpm w/ these cams.
Main concern is about the IAB stuff? Is there a way around this? WOuld there be any problems w/ running the gsr ecu if I tune the fuel w/ a fpr?
as far as the iab's, you'll be fine
i dunno, you gonna run lean, and if you up it up with the fpr; timing will still be off.
bigger bores need more timing/
ill say get it tunned
Any one else have experience with this setup?
I have a b20b currently running in my car, just rebuilt a gsr head completely stock. I have an obd1 p72 that I want to use until I get it tuned.
Will this blow up in my face?
Thanks,
Thanks,
