d16a6 head on a z6 block
Old Sep 9, 2004 | 05:58 PM
mrmechanic's Avatar
Default d16a6 head on a z6 block
I just got a d16z6 block from a buddy, he suggested using my stock head on it for higher compression however i already have an a6 head i want to use, and apply forced induction. The a6 head will fit to the z6 won't it? and who has used head studs? How good do they work compared to regular bolts? thanks
Old Sep 9, 2004 | 06:30 PM
Bserieskllr's Avatar
Default Re: d16a6 head on a z6 block (mrmechanic)
yes you can put the head on but you have to put the oil jet in from a non vtec D.
but this is gonna lower your compression not bump it up....the a6 has a bigger combustion chamber...your gonna have to swap different pistons in too bump the compression.
Old Sep 9, 2004 | 07:26 PM
ihateslowhondas's Avatar
use the a6 head so the compression is lower and run alittle more boost to make up for the compression....... just a thought
Old Sep 10, 2004 | 06:54 PM
mrmechanic's Avatar
Default Re: (ihateslowhondas)
yeah i know that the compression will be low, so i was going to use boost to make up for it. thanks
Old Sep 12, 2004 | 04:19 PM
mrmechanic's Avatar
Default Re: (mrmechanic)
out of curiosity why do i have to have the oil jet in it?
Old Sep 12, 2004 | 05:40 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
the oil control jet from a d16a6 is in the block...i believe 92+ d-series is in the head. im not sure how you would get an oil control jet into a head and block without one. search is your friend....
Hektor
Aug 2, 2009 10:27 AM
mike93eh2
Feb 11, 2009 08:09 PM
TorturedSol
23
Apr 10, 2006 07:46 PM
loughnan
Mar 20, 2005 06:39 PM
