H22 Block Pictures
Old Sep 9, 2004 | 04:25 PM
ranta18's Avatar
Default H22 Block Pictures
9.5 cc 88mm IB Spec Wiseco's on IB Spec H beam rods
Jeff @ Import Builders
Old Sep 9, 2004 | 04:42 PM
EKhatch's Avatar
Default Re: H22 Block Pictures (ranta18)
Damn, that looks nice. When is it due for ignition?
Old Sep 9, 2004 | 05:04 PM
H23vtecEG's Avatar
Default Re: H22 Block Pictures (EKhatch)
i'm all wet
Old Sep 9, 2004 | 05:09 PM
Pacman
Guest
Posts: n/a
JEFF dope *** guy
nice block
Old Sep 9, 2004 | 06:36 PM
1 2 NV's Avatar
Default Re: H22 Block Pictures (Pacman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pacman &raquo;</TD></TR><TR><TD CLASS="quote">JEFF dope *** guy
nice block </TD></TR></TABLE>
jeffs a bitch, ha, JK jeff.
those pistons are huge. nice lookin block!!!!!!!!! me and jeff have something in the works for next yr. H U G E pistons.
Old Sep 9, 2004 | 06:53 PM
teg92's Avatar
Default Re: H22 Block Pictures (1 2 NV)
i see hot spots everywhere
Old Sep 9, 2004 | 07:27 PM
ranta18's Avatar
Default Re: H22 Block Pictures (teg92)
Thanks guys. Jeff has been a great help. Plans are to get it running by late spring.
I have yet to sand down the sharp edges to help eliminate hot spots. They are just in there for the pictures.
Old Sep 9, 2004 | 07:28 PM
GumballNA's Avatar
What sleeve's are those? and what rods? and did IB actually build the motor?
Old Sep 9, 2004 | 07:33 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg92 &raquo;</TD></TR><TR><TD CLASS="quote">i see hot spots everywhere
Should have done alot of sanding down all the sharp edges on those pistons before installing them, this to help prevent detonation.
Old Sep 9, 2004 | 07:48 PM
ATS*Mark's Avatar
OG triple OG
Default Re: H22 Block Pictures (Pondus)
i wanna see some IB spec 2.7 litre k24 block pistons
that **** looks so nice!
Old Sep 9, 2004 | 07:53 PM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">
Should have done alot of sanding down all the sharp edges on those pistons before installing them, this to help prevent detonation. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">
I have yet to sand down the sharp edges to help eliminate hot spots. They are just in there for the pictures.</TD></TR></TABLE>
Should have read all the replies.
Old Sep 9, 2004 | 08:35 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Should have read all the replies. </TD></TR></TABLE>
Yeah saw that after posting my reply, **** happens
Old Sep 9, 2004 | 11:52 PM
MrMike's Avatar
so purdy good luck on the new setup
Old Sep 10, 2004 | 01:46 AM
jdmh22eg's Avatar
Default Re: H22 Block Pictures (MrMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GumballNA &raquo;</TD></TR><TR><TD CLASS="quote">What sleeve's are those?</TD></TR></TABLE>
Old Sep 10, 2004 | 04:36 AM
ranta18's Avatar
Default Re: H22 Block Pictures (jdmh22eg)
Golden Eagle Godzilla sleeves.
IB Spec H beam rods w/ ARP bolts.
I do all the engine building on my motors.
Old Sep 10, 2004 | 06:44 AM
NAstreetEH2
Guest
Posts: n/a
:sigh: i'm the only person to not run an h-beam rod......
nice stuff, what's the rest of hte setup going to consist of?
Old Sep 10, 2004 | 07:11 AM
ranta18's Avatar
Default Re: (NAstreetEH2)
2005 Race Engine Setup:
1995 JDM Honda H22A & 5spd w/ LSD
Golden Eagle Sleeves
IB Spec Wiseco Pistons
IB Spec Rods
Port & Polished Head
Rocket Cams, Springs, & Retainers
Imagine Engineering Race Header, Intake, & Intake Manifold
STR Fuel Rail, Fuel Pressure Regulator, Cam Gears, 70mm Throttle Body, & Cam Seals
NGK Spark Plug Wires & Plugs
Golden Eagle Electric Water Pump
Old Sep 10, 2004 | 07:20 AM
NAstreetEH2
Guest
Posts: n/a
so you're going wiht the RObert REgrinds?
Old Sep 10, 2004 | 07:42 AM
ranta18's Avatar
We're going to try and work something out and see. Nothing definite or specific specs have been layed out. I'd like to go with a VTEC killer cam too. No transfering over problems, easier to clay and check valve to valve clearance, etc. I need to send the head off first.
Old Sep 10, 2004 | 07:51 AM
NAstreetEH2
Guest
Posts: n/a
who's getting the head???
i mean, the H22 head is REALLLLLY good stock, ya know
Old Sep 10, 2004 | 08:11 AM
ranta18's Avatar
The head master.... Brad @ RLZ
Old Sep 10, 2004 | 08:29 AM
NAstreetEH2
Guest
Posts: n/a
just making sure
Old Sep 10, 2004 | 03:21 PM
GumballNA's Avatar
if ya don't mind me asking how much u pay for the GE godzilla sleeves .
Old Sep 11, 2004 | 08:44 PM
hayabusa160's Avatar
man thats sexy
Old Sep 12, 2004 | 08:44 AM
ranta18's Avatar
Default Re: (GumballNA)
I got the block fairly cheap and it was already sleeved. Then I sold my stock block on Ebay. In the end I payed very little for it. I can get it done for a good price if you are interested.
