Accord axle nut removal help
Old Sep 9, 2004 | 03:38 PM
xyooj's Avatar
Default Accord axle nut removal help
First of all thanks for your time. Second y did honda make the front rotor set up like this? How do you remove the axle nut? I tried impact gun, jumping on it with a 5ft cheater bar( thank god for craftsmans life time warrany on tools) with no avial but a broken rachet. Is righty tighty and lefty loosie right? IS the axel nuts threaded the opposite way? Help its driving me nuts. Need to get to those brakes and rotors. Thanks
Oh yeah..95 accord ex
Old Sep 9, 2004 | 03:46 PM
H22SiRaccord's Avatar
Push the pin in? Second if you have tried a impact gun and jumping up and down on a breaker bar chances are it is not going to move. How much pressure are you runnin' on the impact and how well of a impact gun is it.
Old Sep 9, 2004 | 04:08 PM
CDEEE5's Avatar
Default Re: (H22SiRaccord)
I could have sworn there is a special tool for this that makes your task ALOT earlier...
Old Sep 9, 2004 | 04:16 PM
xyooj's Avatar
yea...the dent is removed on the nut... Impact gun is a pretty good one...MATCO puts about 400lbs one that a tech uses in the shop. Special tool?
Old Sep 9, 2004 | 04:32 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: (xyooj)
im pretty shure it you lossen it by going clockwise..
Old Sep 9, 2004 | 05:05 PM
xyooj's Avatar
Default Re: (91EXRMANUAL)
U sure..as in righty loosie and lefty tighty? Anyone confirm this?
Old Sep 9, 2004 | 05:22 PM
fourthgenhatchB17's Avatar
Default Re: (xyooj)
I dont believe there are special threads...just loosen it like u would any other bolt. Get a bigger impact wrench and turn up the PSI. I sometimes have trouble with my 550 ft lb set at 120 psi. Try hitting the nut both ways (loosen, tighten, loosen, tighten) to jar it loose. Get the penetrating oil out too. Good luck. I dont work on Accords, but u encounter this same situation with crank pulley bolts.
Old Sep 9, 2004 | 05:40 PM
xyooj's Avatar
yea..timing belt on my teg soon
Old Sep 10, 2004 | 06:31 AM
xyooj's Avatar
Old Sep 10, 2004 | 07:28 AM
TxTuner
Guest
Posts: n/a
Default Re: (xyooj)
PB Blaster works great on stubborn bolts Good luck
Old Sep 10, 2004 | 10:33 AM
Its_real&its_spectacular's Avatar
New User
Default Re: (TxTuner)
By the way, yes it is counterclockwise to loosen both of them. Good luck. The special tool is either a powerful impact gun or a breaker bar with an extender (like a shop jack handle) on it.
Old Sep 10, 2004 | 12:23 PM
TxTuner
Guest
Posts: n/a
Default Re: (Its_real&its_spectacular)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyooj &raquo;</TD></TR><TR><TD CLASS="quote"> I tried impact gun, jumping on it with a 5ft cheater bar( thank god for craftsmans life time warrany on tools) with no avial but a broken rachet. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Its_real&its_spectacular &raquo;</TD></TR><TR><TD CLASS="quote">The special tool is either a powerful impact gun or a breaker bar with an extender (like a shop jack handle) on it.</TD></TR></TABLE>
He already tried the impact, and oh yeah, what do you think a CHEATER bar is? Nothing new here so are you just upping your posts or what?
Old Sep 10, 2004 | 01:59 PM
xyooj's Avatar
Update...axle nut came loose with a 600+ impact gun... WOW.... now how the hell do you take the hub and the rotor off..doing a search as we speack.
Old Sep 10, 2004 | 07:25 PM
BlazeTeck2000's Avatar
Default Re: (xyooj)
well not to sure if the 95 is the same as the 90 -93 from what i know you need a specail tool to take out the rotors
Old Sep 10, 2004 | 08:30 PM
TxTuner
Guest
Posts: n/a
Default Re: (BlazeTeck2000)
Damn honda's need a special tool for everything!!! One more way to keep you going to the dealer
Old Sep 10, 2004 | 08:59 PM
well your right about that .... but the tool is used on other cars ... its pressured on rotors its a tool that has 4 legs that go on each bolt and you pull on it a few times then it comes out ... i had to do it on mine and it cost me 60 bucks to chage them ... prices in nyc tho .... had a crack head do it lol
Old Sep 11, 2004 | 03:25 AM
xyooj's Avatar
Where can I get this tool....bump..need car back
Old Sep 11, 2004 | 03:42 AM
m0t0rhead's Avatar
Default Re: Accord axle nut removal help (xyooj)
Counter-clockwise to remove. An impact or... leave the wheel on the car touching the ground and get a big *** cheater bar. Enjoy.
Old Sep 11, 2004 | 08:39 AM
Default Re: (xyooj)
well if you want to change your rotors i would take it to the shop ...(where u know its cheap) i had both front rotors changed for $60 crack head price...but i went to the shop and it was $80 ...the tool it self is like $150....so i think u would wanna go to the shop
Old Sep 11, 2004 | 09:25 AM
m0t0rhead's Avatar
I don't know where you buy your slide hammers, but that's a steep price.
Old Sep 11, 2004 | 01:23 PM
brads94accord's Avatar
replacing the rotors really isn't as hard as people make it out to be. i changed mine out in under an hour. you need to rent a slide hammer, i rented one for $20 from autozone. then you wanna buy a 2 jaw gear puller. its your best friend. i have used it a few times now. it was $20 from advance auto parts. i used it to seperate the lower ball joint.
first you wanna remove the axle nut which you have done
then you wanna seperate the lower ball joint by removing the cotter pin, and taking off the 17mm castle nut.
then slide the rotor/hub around and remove the 4 bolts that bolt the hub/wheel bearing to the spindle.
then remove the 4 bolts that bolt the rotor to the hub on the front side. then put your slide hammer on two of the lugs and tighten it down with two lug nuts. then slide away and take out your anger. took me about 7-8 blows per side. it will pop right out
then put your new rotor on and tighten the bolts down. now put the hub back into the spindle and tighten the bolts in from the backside. it will pull the hub and wheel bearing back into the spindle. then tighten everything down really tight.
make sure you put some locktight on the bolts that bolt the rotor to the hub and tighten them as tight as you can. mine ended up backing out after a few weeks. luckily i caught it in time.
then bolt everything else you took off and be sure to replace the cotter pin.
Old Sep 11, 2004 | 11:50 PM
accordfreak's Avatar
Default Re: (brads94accord)
i used a breaker bar with an extension and jumped on it
Old Sep 12, 2004 | 01:42 PM
Riceburner247's Avatar
Default Re: (accordfreak)
I use my 18" Craftsman 1/2" breaker bar with 4' pipe I bought from Home Depot. Just have someone stand on your brake pedal while breaking the nut loose. Works everytime.
Old Sep 12, 2004 | 02:25 PM
drkshdw107's Avatar
be careful when taking a slide hammer to your rotor...i experienced this on my accord...i took the bolts off the front and off the back side of the rotor and still managed to split the wheel bearing apart...luckily i didn't loose any of the ***** inside...but this is a common problem with this type of rotor setup...good luck.
Old Sep 13, 2004 | 12:02 AM
hondaacuratech's Avatar
using 36mm short socket with impact gun, tighten and loosen couple times with WD40. loosen ball join nut and remove the outter axle off the hub bearing, there are four 10mm or 12mm bolts ( 12 point bolts ) loosen them and remove the whole hub assembly off the knuckle then loosen four 14mm bolts ( becarefull they are easy to strip). I do not recommended to use slide hammer because you will damage your hub bearing when you put them back together. take your time . good luck.
