*Rear Brakes*
Old Sep 9, 2004 | 03:05 PM
Cabby89's Avatar
Default *Rear Brakes*
OK Im putting back together the rear brakes but need some help. We are currently trying to load the calipers with the pads. Suck a pain unless Im doing it wrong but its like you have to twist it and turn it to get it to fit. But I need to get the piston pushed in the caliper to make some more room. Can it be pushed in or is it a screw style???
Also brake bleeding, what are the proper procedures???
Old Sep 9, 2004 | 03:07 PM
Tweakmeister's Avatar
Default Re: *Rear Brakes* (Cabby89)
search...this is covered every week (if not every day)
it's screwed in. keep an eye on the reservoir as it will probably overflow (brake fluid will remove paint if left on)
Old Sep 9, 2004 | 03:17 PM
Cabby89's Avatar
Default Re: *Rear Brakes* (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">search...this is covered every week (if not every day)
it's screwed in. keep an eye on the reservoir as it will probably overflow (brake fluid will remove paint if left on)</TD></TR></TABLE>
Have been trying that about the screw in and couldnt find it. But thank you.
AS for the bleeding, seems like there are so many things people are saying but its starting to confuse me.
Caliper is actually off the car.
Old Sep 9, 2004 | 04:45 PM
Built B18ABorC's Avatar
you should get this type of tool. Its a universal brake caliper compressor. You just use an extension and ratchet. Worked for me. Turn clockwise to push in the claiper.
Old Sep 10, 2004 | 08:44 AM
GetawayInMoscow's Avatar
Default Re: *Rear Brakes* (Built B18ABorC)
Use a C clamp...thats what I do on my Jeep....
Old Sep 10, 2004 | 09:04 AM
DA Teg D00D's Avatar
Default Re: *Rear Brakes* (GetawayinMoscow)
done this several times and the best thing is to use that universal tool for the rear (screw in) and the c-clamp + a block of wood b/t the piston and the screw on the clamp to better distribute the force. enjoy!
Old Sep 10, 2004 | 09:17 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: *Rear Brakes* (DA Teg D00D)
C-clamp is only for use on the front caliper pistons. The rears must be turned using a big screwdriver or the tool pictured above.
Old Sep 10, 2004 | 09:21 AM
95 integra's Avatar
Default Re: *Rear Brakes* (PatrickGSR94)
Personally I use a set of needle noise to screw it back in.
Old Sep 10, 2004 | 09:32 AM
sabotage7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">C-clamp is only for use on the front caliper pistons. The rears must be turned using a big screwdriver or the tool pictured above.</TD></TR></TABLE>
this is correct!....and needle nose pliers work too if you dont have the tool!
Old Sep 10, 2004 | 01:05 PM
Default Re: *Rear Brakes* (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Personally I use a set of needle noise to screw it back in.</TD></TR></TABLE>
But if the calipers are old and have a little bit of resistance the universal tool works best.
mish__
Suspension & Brakes
12
Apr 5, 2012 03:40 PM
immajackuup
17
Jun 2, 2008 09:46 AM
NCJDMEK9
Jan 31, 2008 10:31 AM
sting94112
Dec 5, 2003 02:45 PM
wizzards581
Sep 6, 2003 12:15 PM
